May 22, 201213 yr Anyone have backup camera? If so show a picture of where located, I am as bad as a girl trying to find location.
May 22, 201213 yr I bought an Edge backup camera that mates to my Edge CTS monitor. The camera comes mounted to a rear license plate frame. I haven't mounted it yet so I can't give you a picture yet but if you go th this site you can see the product marketing picture of the camera mount. http://www.edgeproducts.com/product.php?pk=129&pvk=438
May 22, 201213 yr Author Does any other cameras work with the edge? I thought about replacing gauges with edge.
May 22, 201213 yr mine also mounts to the license plate. The downside is, if you're using it for the hitching procedure, and have a drop hitch (mine is 10k lb. 6" drop) then you'll just barely see the top-most part of the ball. I'll try to get a picture today, if it stops raining..
May 22, 201213 yr Author Well I am using a cheap Chinese one that was shipped from china. I like it cause you can rotate it. Plus I won't mounting one on back of fifth wheel. But I don't want to pay 400 for edge for a fixed camera.
May 27, 201213 yr Finally got the Edge Camera installed today (all the wiring isn't completed yet).The frame that mounts around the license is very heavy duty. The camera moves up and down for adjusting the picture. It also has LED lights to light up the picture at night (low light).I had a plastic cover over my license plates to help keep them clean and the camera frame allowed me to continue to use the same setup.
August 18, 201213 yr Does any other cameras work with the edge? I thought about replacing gauges with edge. The Edge Insight display says it will take any camera input that uses an RCA jack as the connector to the camera. I just completed my wiring hookup and have some pictures and write-up about the camera here: http://forum.mopar1973man.com/threads/5902-Backup-Camera/page2?highlight=camera
April 18, 201313 yr I bought one of those wireless ones,only used it a couple days. Signal from camera was intermittent, and wireless security cameras ,would trigger it causing the monitor to randomly turn on-pretty annoying..
