help with powersteerin
this was about a 100 miles ago or alittle less one of my powersteering lines were clogged and i clean and rebled the system when i putted the fluid in it i over filled it just a little bit but i just noticed this evenin that i lost about a pint and i can not figure out where its goin and also another think i noticed was the fluid was a light brown and it smelled like oil but i putted fresh fluid in it but i dont if this is normal but i purty sure it aint
  • Replies 7
  • Views 3.6k
You got to remember there is nearly another quart caught in the steering box and the hyro-booster...What I do is disconnect the return line from the PS pump and cap that nipple. The route the the return line back to a waste bucket. The start the ngine and rock the steering left or right till the pump runs dry. This only takes a few seconds and then shut down the engine. The re-fill and do again. I do this till the system is completely purged out. Then hook up the reutrn line and re-fill... This should help...
alright man i appricate it it my take a few days but ill let you know and you wouldnt know of a injection pump leakin oil do you?
Opps... I had to look again... This is a P-pump truck... That is engine oil lubed so there could be few places it leaking from I would check the supply line...
thanks and i dont mean to sound dumb or anythang but where is that actually at like where it connects and other connection and thanks again
If I'm not mistaken the oil feed comes off the vacuum pump feed line and heads up to the P-pump. So there should be a braided oil line that runs up to the P-pump that most likely have a banjo bolt holding it on. As for exactly where I'm not sure. I've never had the pleasure of working on a 12V 2nd gen yet...
what is the latest on this??????
i got gotcha now but i think i would have to agree with ya on that one havin no pleasure workin on a 2nd gen 12v LOL
Guest
This topic is now closed to further replies.
