Torque management?
I have a problem that ain't really a problem but I can't spool my turbo up for a good launch in 1st gear. It seems the engine just defuels or somethin and I just get about 9lbs of boost max. Smokes like crazy tho so I know it's getting fuel!! Any1 familiar with this??
  • Replies 3
  • Views 2.1k
Idk exactly, but even with torque management i get more than 9psi when taking off in first.
No wheel speed = no fuel to build boost. BD Rad box or a Blue chip box will eliminate the torque management or a smarty or Quad programmer will lessen the effects but not disable it.With TM it needs to see wheel speed before it will allow enough fueling to make boost.
