Heating and A/C system problems
- Replies 8
- Views 3.3k
Mopar1973Man 4 posts
FlatTwin 2 posts
flagmanruss 1 post
guesswho512 1 post
Guys, Am still having problems with the heating and cooling in the cab of the truck. Driving home tonight it was getting a bit chilly here, in the mid 50's. Turned the heat control from full cold to mid-way up the scale. Nothing happened at all. Had the blower on fresh air. Turned it 3/4rd hot and still no change. Finally went full tilt hot and about 3-5 seconds later heard a vent door shut and immediately it got full hot.Ok, so we know that there is hot water in the heater core. Turned the temp control back to 1/2 scale and no change. Turned it back to full cold and no change, its still full tilt hot. After about 15 seconds it went from full hot to full cold outside air. Stayed that way for 30 seconds or so then "clunk" the flapper door somewhere in the dash closed and full hot again.It then cycled back and forth like that all the way home. Its got a mind of its own. I need to make a trip back to the mid-west next week and would really like to have heat on the way there. Anyone have something like this happen or ideas or suggestions where to look? Thx,Joe
