When I did my valve lash adjustment I did not have a barring tool so I used the alternate method to turn the engine backwards using a ratchet and socket on the alternator...
Here is my question/comment... I turned engine till I got TDC (everything was nice and smooth and quiet) did the valve adjustments then started turning engine to get to BDC... while I was turning everything was smooth and quiet and all of a sudden I start to hear a clicking noise every time I would turn over the engine... the sound persisted for about 5 or 6 turns on the rachet and then stopped... I never heard it again after that...
It noise/clicking sounded like it was coming from the aft bottom of the eng block oil pan/starter area...
Ever since then I have had a lumpy idle at startup issues... :banghead:
I wonder if I damaged something internal...
99 Ram 2500 4x4, Auto, QCab longbed: Edge CTS juice/attitude, afe Stage II cold air, Raptor 150, Industrial Injection 85's, 5" MBRP turbo Back...
