No 4 wheel drive, tracking Vaccum
- Replies 6
- Views 2.5k
ISX 3 posts
idahocountryboy 2 posts
Haggar 1 post
Ok... Researched this, but to no avail. This site is not working for me, but I want to see it http://mopar.mopar1973man.com/cummin...d/vac-diag.jpg So, in Texas, it rains and when it does it POURS!!! and when your 4x4 doesn't work it's not good in this odd soil. Started at the vaccum pump, has good suction there, tracked it too the T section on the fire wall (the grey/white line). This line has suction that is lookin like it goes to the T-Case... Then kinda disparages but I haven't put a lot of time into finding it from there. It's hard to get to the top of the T-Case... So then I went to the CAD (actuator) on the front passenger side of the axle. The CAD has no suction, so fallowed the lines to the drivers side of the transmission where they run on the cross member (steel tubes connect to the plastic tubes) No suction at the plastic tubes. (all test done with the truck running) So... how do I get a test to the top of the T-case? Any other ideas? Second... The CAD was rotating pretty essay, is that good?
