Fuel gauge questions
- Replies 7
- Views 2.1k
98whitelightnin 3 posts
krj 2 posts
diesel4life 1 post
Homestead 1 post
I'm about to order an Isspro EV fuel gauge for my truck from Vulcan. Their 'kit' comes with: "isolator, 30" universal gauge hose with adapters, tubing kit w/ fittings". For the fuel pressure access, I'm assuming I need the tapped 12mm bajo with seals, as opposed to the other push lock fuel tee's offered.I've read alot on here, and other forums, of guys using needle valves in the system as well (or in place) of the isolator, also a tee fitting in there to still preform direct fuel pressure tests. Believe Mike uses air brake line, I would guess that would be in place of the "universal gauge hose"? Just wondering if I would be better off putting my own 'kit' together, and if so, what would the experts (that's you) suggest. Once again, a newbie thanks you for all your input.Kevin
