- Replies 5
- Views 2.5k
mr.mindless 2 posts
Mopar1973Man 1 post
flagmanruss 1 post
ISX 1 post
Unfortunately, it's gallons of oil not of diesel.Started yesterday on a 600 mile round trip. Oil light was coming on as I got to my destination in Newburgh NY and I added 5qt. It had last been topped off ~1100 miles ago. I added a gallon when I got back to Rochester 300 miles later. I saw the oil light flash at me one more time after a bunch of idling and ~30mi of around town running after that, I'm REALLY hoping that was a fluke. It usually it has relatively high consumption, adding up to 1-3qt/1000 miles, but this is pretty unheard of.It's an external leak. The bottom of truck and trailer are well rustproofed again. Very very little on the bottom of the hood so it's not front main.I can see some oil on top of the timing housing near the water pump/idler pulley area, and after getting off the highway it looked like I had a decent amount puddled under the breather tube too - but the oil under the truck started further forward so it could just have been running down the outside of the tube too. KDP is tabbed, but it almost looks like a cracked timing housing. I crashed this truck about 1700 miles before I left on yesterday's 600 mile trip and it's been fine since, but it did touch the motor on the front passenger side (had to replace alt & bracket; fan, clutch, idler pulley; lower water neck was cracked when the fan hit it).It doesn't leak at all at idle that I could notice though. This is going to take some digging, I think. Booo.
