Maximum safe boost on a stock engine?
- Replies 5
- Views 1.9k
Mopar1973Man 2 posts
diesel4life 1 post
ABennin 1 post
Truckaddict 1 post
My wastegate is apparently stuck shut. For a long time I was trowing overboost codes and defeuling. Then I out a XZT on it and no longer worried about it. The boost fooler in the XZT made the sticking wastegate work to my advantage. Well now it appears that the wastegate is not doing anything anymore and I have bounced of of 30 lbs. of boost a couple of times. I don't know how far the fooler goes or if it totally cuts out the defuel and codes. I do not want to be blowing the head gaskets out.Rick
