whats up with suv lights?
i had there headlight wiring harness conversion on 2000 ram before i went through bankrupcy back in 2009-2010. now i got another truck. i went to there website to order another one. and there website seems to be down?? been checking back for few monthes and still no change. please forgive if this is not the right spot to post but not sure where to post it. whats the deal with www.suvlights.com ???? also anyone have a wiring harness from suv lights that i could buy used???? :doh:
  • Replies 13
  • Views 6.2k
I tried them too and finally gave up. There are a few members here that have made their own harness.
- - - Updated - - -
Nevermind, I just saw you were one of the guys making his own harness.:doh:
I just use 100w fog lights instead of modding the stock headlights. I was kind of happy about that last night with the heavy snow storm and them being mounted below the front bumper. Very easy to see long distance compared to the factory head lights.
i have factory fog lights on mine with silverstars in them. they are not to bad. but yes the fog lights are nice to have when you need them. also works pretty good as a back up. about 6 mothes ago i was comming home from deluth,mn pulling a trailer with a load on it at night. when all of sudden my headlights went out on me. thank god i had the fog lights as a back up. it sucked driving with just the foglights but it was better then nothing. turned out it was the headlight switch that went bad on me. the truck now has a newish headlight switch and turn signal switch.
Daniel Stern wont return your calls or emails either.:shrug:
i emailed him last night and got a reply from him last night as well.
What did he say? I left a message and emailed over a month ago and still ne reply.
here is the reply i got.
Hi, there. Thanks for your persistence -- either your first
mail didn't reach me, or I overlooked it. Didn't mean to
seem as though ignoring you!
Ordering info follows technical info:
Put in a set of the '99-'01 Dodge Ram 1500 Sport headlamps,
which are
*much* better than the lamps all non-Sport '94-'02 style
Rams got. The
Sport lamps use two bulbs per side (a 9007 high/low and a
9004 high-only)
and produce much more effective, longer and wider, better
focused beam
patterns. They physically fit right in, but require some wiring
adaptation, which is just as well since the factory wiring
tends to starve
the bulbs.
You need:
-a set (left and right) of the '99-'01 Dodge Ram 1500 Sport
headlamps. Get
the real ones from the dealer or www.chryslerpartsdirect.com
, not the
Taiwanese knockoffs from eBay or elsewhere on the internet;
the low price of the aftermarket units is attractive, of
course, but despite "OEM quality" and "DOT/SAE approved"
claims, they are junk (more info below). Factory part
numbers are as follows:
Headlamp, left: 55077 025AC
Headlamp, right: 55077 024AC
Park/turn lamp, left: 55077 033AC
Park/turn lamp, right: 55077 032AC
The original park/turn lamps can be used with the new
headlamps; I've
listed the Sport type park/turn units because their
clear-lens design
matches that of the Sport headlamps. Also note that the
above numbers may
from time to time be updated or superseded as noted when you
do a part number search on chryslerpartsdirect.com or
realmopar.com - go ahead and buy whatever the latest part
number is.
-A Dodge Ram conversion wiring and relay installation
package RIK-RAM, $79
here.
The installation package includes all necessary plugs,
sockets, terminals, fused fuseholders, relays, relay
brackets, terminal blocks, etc. -- everything except actual
wire -- to install the new headlamps _and_ eliminate the
voltage drop present in the factory-type wiring. You supply
your own wire and use the parts from the kit to build up
your own wiring harness. Specific instructions are provided,
and the concept is explained at
http://www.danielsternlighting.com/tech/relays/relays.html
.Parts are specially made premium-grade items (e.g. ceramic
headlamp sockets) that accept large-gauge wire; this is not
the "consumer grade" junk you can find at the parts store.
Or, I can have my harness builder custom build you a
ready-to-install harness assembly using the same components.
Cost for this option is $161.44 (including parts and labour
- you pick _either_ the relay kit _or_ the custom-built
harness. It costs more than the chintzy and unreliable $30
to $50 Chinese prefab harnesses because it is not a Chinese
prefab harness). Either way, the in-cab switches continue
working normally, and you will not need to cut or otherwise
disturb any of the vehicle's original wires. And either
method will work fine on a dual-battery Ram.
-A set (two 9007 and two 9004) of ultra high efficacy bulbs.
The best 9007 bulbs presently on the market are the Philips
Xtreme Power items:
http://www.amazon.com/dp/B00480N16S/
or the GE Night Hawk Platinums:
http://www.amazon.com/dp/B002UX7I9G
The best 9004 bulbs presently on the market are the GE Night
Hawk Platnium 9004NHP:
Do not buy blue or "extra white" bulbs (Silver Star, Crystal
Vision, TruView, Hoen, PIAA, etc.); despite the heavy
advertising push and claims of "brighter and whiter" light,
they actually produce _less_ light due to the blue glass
they use.
More info on original vs. aftermarket lamps:
All of the aftermarket lamps, whether they're
original-looking or restyled, are trash. The low price is
attractive, but the quality, performance, and durability are
all substantially and dangerously inferior to the genuine
items. This goes for all the many brands of aftermarket
lamp—TYC, Genera, Depo, DJAuto, ScanTech, and many other
brands (and unbrands) of original-looking and restyled
lamps, not to mention the newest wave of trash coming in
from China under names like Helix and Sonar (projector
headlamp conversions, clear-lens conversions, angel eyes,
LED lines, etc...every bit of it dangerously badly made).
There is no optical engineering behind any of these; they
are headlamp-shaped toys made from physical copies of the
originals, which is not even close to adequate. One might as
well make a mould of your eyeglasses lenses and expect to be
able to cast new working eyeglass lenses from the mould. The
level of shape precision required to accurately focus the
beam can only be achieved with optical engineering _from
scratch_. Copies don't even begin to get in the ballpark.
Light distribution is way, way out of line with what it
should be. Usually the DOT and/or ECE safety approval or
certification marks are fraudulent or counterfeit.
"Perfect OE fit and performance" is often promised in the
ads for the copycat lamps. This is an out-and-out lie. Take
a look at
http://www.capacertified.org/press/CAPALighting3.pdf , which
is the report on a large government-sponsored test of OE vs.
TYC and Depo versions of simple, cheap American-vehicle
headlamps. Even though TYC is widely regarded as the
least-awful of a pathetic bunch, still a complete failure by
the TYC & Depo units (see page 21 and 30 if you don't have
time to read the whole report).
There is only one proper operational setup for the Sport
lamps, and that is as follows:
Low beam mode: Low beam filament of outboard 9007 bulb on,
all other filaments off.
High beam mode: High beam filament of outboard 9007 and high
beam filament of inboard 9004 on, all other filaments off.
The low beam filament of the inboard 9004 is not used --
these lamps do not have optics to focus the light from it.
In NO case are the low beam and high beam filaments on
together! Two-filament headlight bulbs are pressurized to
about 10 atmospheres COLD. They are not designed to handle
the heat (or the current on the common filament support
lead) of running both filaments at the same time for more
than very brief periods during beam changeover or headlight
flashing. Doing so carries the very real risk of the bulb
grenading inside the headlamp, destroying it (and holding
the beam selector switch to run both at the same time will
cook your wiring and switches). Some people who think
they're clever wire it up this way anyhow, and the "Brite
Box" people have made a business out of
this "clever" (not) modification.
Daytime running lights:
If yours is a Canadian-spec truck (either by original
manufacture or by private importation), or you're not in
Canada but have had the Daytime Running Light function
enabled, you will need to rework the daytime running lamps.
The stock DRL configuration runs the high beam circuit at
reduced duty cycle. This is not compatible with any kind of
relay installation.
http://www.lightsout.org/disable.html#Dodge has info. Once
you have installed the new headlamps, you need to re-enable
the DRLs.
Daytime running lights do significantly reduce your risk of
being in a crash during the daytime, and are required on all
'90 and newer vehicles in Canada. There are many ways to
implement them, each with various drawbacks and benefits. If
you want (or need) to have (or keep, after you install
headlamp relays) a daytime running light function on your
vehicle, the best (most beneficial, least detrimental)
implementation is the steady-burning operation of the front
directional signals. They produce a light distribution with
a wide view angle, are generally well located for DRL
service at the outboard edges of the front of the vehicle,
consume considerably less power than any headlamp-based DRL
implementation, use light sources of generally much longer
life than any headlamp bulb, do not encourage improper
nighttime use of lights, and do not require additional
lighting devices to be added. Most recent Cadillacs,
Chevrolet/GMC large vans and minivans, Corvettes since 1997
in the US and since 1990 in Canada, some Toyota and Lexus
models, certain new Lincolns and Chryslers and assorted
other vehicles use this implementation. It is steady-lit
operation of the bright amber turn signals (except when they
are flashing to signal a turn), not operation of the dim
parking lamps; parking lights are not bright enough and
don't have the right view angles to serve the daytime
running light function. Turn signal DRLs comply with US and
Canadian Motor Vehicle Safety Standards #108 and are
approved in all states, provinces, and territories. You can
easily enable this functionality in your vehicle using a
DRL-1 module ($42); see
http://dastern.torque.net/Mods/DRL/DRL1.html for
instructions and
http://www.allpar.com/fix/electrical/DRLs.html for an
example installation.
HOW TO ORDER:
Orders may be sent via e-mail to: dastern@torque.net
You may also voicemail or fax your order toll-free on
1-866-861-8668.
Please note this is a recorded orderline only. If you wish
to speak to me
in person, please use 303-835-1300.
PLEASE INDICATE:
The quantity of each item you wish
The address to which you want the items shipped, if it
differs from the
billing address
All items are warehoused in the USA. Please state the type
of shipping you
wish -- DHL, FedEx, or UPS ground shipping is standard on
shipments within
the US; all other service levels are available on request.
Shipments to
Canada go via Postal EMS unless otherwise specified. If you
have an
account with one of the carriers I use, I'll be happy to
ship on your
account; just provide the details with your order.
Please also state whether the delivery driver has permission
to leave the
parcel at your doorstep if you are not available to accept
and sign for it
in person.
CREDIT CARDS:
I accept Visa and Mastercard. Orders are processed securely
and customer
card info is not retained after processing your order.
The following information is required in order to process a
credit card
order:
Card type
Card number
Expiry date
CVV code (last group of 3 or 4 digits on back of card)
Your name as it appears on the card
Billing address
Phone number
PAYPAL:
I accept PayPal. If this is how you wish to pay, please send
your
shopping list and I will send you a PayPal invoice from
which to pay.
Please _do not attempt_ to pay by PayPal until you have
received a PayPal
invoice for your order.
I look forward to hearing from you.
Highest Regards,
Daniel Stern
Thanks, I think I will get him to send me a Paypal invoice.
your welcom.
thats what i'm working on with him right now.
- - - Updated - - -
just paid for my order with him through paypal. so will see how it go's
Any news on this? I think I will get him to get his guy to build mine because my soldering skills are lacking.:whistle:
got my package from him today. i got the $79 kit because i was low on money at the time.
he also has option for $161 all made up as well. only problem my kit did not have any instructions how to install it.
in his email he sent me a link how to install it. his diagram shows 2 relays. but the kit i got has 3 relays? so now i have to figure out how to install his kit?
- - - Updated - - -
i just got my kit today from daniel stern. kit rik-ram. has anyone installed this kit on there truck yet? i need some help with it. here is the link he emailed me how to in stall it-http://www.danielsternlighting.com/tech/relays/relays.html i looked at the link on how to install it. but in the diagram it shows to relays??????????? but in the kit i got it has 3 fuses and 3 relays???????????? where does the 3rd relay and fuse go???????????? i did not get any kind of instruction sheet how to install this for this type of truck?(Dodge ram)
