- Replies 9
- Views 2.9k
diesel4life 4 posts
rdsutton 2 posts
dennhop 2 posts
Mopar1973Man 1 post
While replacing the tranny lines took a closer look @ front rotors! Sever heat stressed & cracked. Q?s I believe the original rotors & Hubs non ABS. So Take hub & rotor off @ same time by the socket on back of hub bolts & use power sterring to press off? Seperate both once off truck & press out wheel studs? On the new hub & rotor, can the rotor be mounted on hub for easy removal of ROTOR only for future replacement i.e. anti sieze all hub & rotor mating surface & hub to axel surface? What are the best hub & rotors for Tow/Hall aplication, tempkin & drilled/slotted zink coated rotors... NAPA premium H&R ....or? Has anyone swaped out to later Generation 2nd, 3rd for easier disassasembly? Do the drilled rotors realy make the stops Shorter by noticably reducing break fade? I realy appreciate all the views & input, thanks Dave.
- - - Updated - - -
ISX will the 00-02 3500 4x4 hubs & rotors fit a 98 3500 4x4? if so order them WO ABS?
- - - Updated - - -
[TABLE=class: tborder, width: 100%, align: center]
[TR]
[TD=class: alt1, bgcolor: #FFFFFF] Looked @ 2002 hub & 98 hub. The 02 hub with studs already in AND a larger flange to hold free floating rotor on the front of it and ABS cable, both are are equal in H, W, & depth, same threds and and same spline pattern and demtions . The 2000 -2002 hubs mount to axel housing like the 98's BUT the rotor mount on the front, EASY rotor replacement. Looked @ both rotors side by side both equal width. the 02 is 1/4in taller. Q, will the 98 break caliper holders & calipers accept is slightly larger dia rotor? will the rotor be set into/ over the axel and not allow the wheel to mount properly? thanks Dave
[/TD]
[/TR]
[/TABLE]
