Wiring question
01 24 valve. Gauge wiring, not using factory cluster, is there a harness that leaves the computer to feed signal to the gauges? I'm wiring them into a Chevy and need the signal wires. Thanks Ron
  • Replies 3
  • Views 1.9k
The signal is all digital from the ECM as far as I know... So you are pretty much hosed for using the feeds from the ECM outside of the original gauges, most, I believe, use aftermarket gauges or a mix of parent/donor sensors to kinda get what they want. I believe that 1997 was the last year of analog style Dodge gauge sending units/gauges.
All cluster gauges are controlled over a 2 wire network bus just like the Ethernet cord for your network. Twisted pair networking.
