74 Dodge D300 Brake's Locking
- Replies 10
- Views 3.3k
GreenRiverCummins 4 posts
Mopar1973Man 2 posts
Wild and Free 2 posts
ABennin 2 posts
Hello all I have a 1974 Dodge D300 i bought this truck in the ongoing hope's of returning it back to it's former glory but I am having on going issue's with the Brake's. Ok when driving down the road after about 3- 5 mile's on a stright road using no brake's the brake's will slowly start to engane.Then completly lock to the rotor's to the point the motor will die from the strees to "push" itself. At this point i'm lost i have replaced the pad's, shoe's, Wheel cylinder's, Drum's, rotor's all line's front to rear top to bottom(Rubber/steel) the Master clyinder twice and Booster 3 time's, rebuilt the carb, changed the intake gasket and on and on i'm stumped my father is stummped and my friend's at the different dealer's are stummped. The brake fluid will leak out of the rubber seal on the top of the Master cylinder and the rear cup in the Master cylinder will suck dry. I've been told again and again that the booster is bad and sucking brake fluid into the carb as to why i had it rebuilt the mech said the hose from booster to carb had Brake fluid in it and the carb had brake fluid resido in it as well. So what are the odd's that the 3rd Booster/Master cylinder is bad and they are all from different part store's one napa 2 autozone 3 adavanced auto so any help or more info required just ask thank's for reading i'm still holding out hope but dad is really tired of it and ready to sell
