  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Ground locations
can anybody help me, i need to know where are all the stock grounding locations in and round the engine area in a 2003 dodge cummins 24v plz
  • Replies 7
  • Views 25.9k
  • Okay I hope your still around after me leaving this by the wayside. I'm sorry for that as I finally got things done around here..... Now if you go into the second gen articles section that is fine too
  • 03-24v/89-12v
    03-24v/89-12v
    My 03 doesn't but my 89 does. ? I hammered out the grounds on the 03, thank you jag1. Now I've moved onto the other woe's this truck is throwing at me. Started with 117 codes got one left and another
I only have experience with locating the second gen grounds. Some so important and yet hidden for some  reason. Also some very important sensor grounds discovered fused together in the wire harness with some sort of  hardened plastic not a drop of solder in them :nono:. I wonder therefore if a 3rd gen harness is similar in some ways..... I can tell you where to look and what to look for if interested.
There are wiring diagrams including the grounds in the articles section here. Sorry but I cant link them on my tablet.
Well do tell
Okay I hope your still around after me leaving this by the wayside. I'm sorry for that as I finally got things done around here..... Now if you go into the second gen articles section that is fine too, but on our first gens there are 4 grounds fused together with some sort of plastic, as I said, but they are located in the wire harness in front of the injection pump. Dodge had no business fusing those without a drop of solder, so most all of us have taken those 4 sensor grounds and soldered them together and bonded them to the back of the gear case under or to the side of the injection pump.There is an already threaded hole in the gear case for a small size threaded bolt to go in there with a ring terminal on the bolt.
Now Dripley has found another location of inferior grounds fused together again with that same sort of hard plastic. He says it's inside the wire harness down near the ECM.
I finally found the all important ground for the power distribution center. Everyone talked about it being down low on top of the wheel well fender in front of the drivers battery except I could never see it there until one day I moved  a small portion of wiring out of the way and there it was. Kind of funny the way Dodge so neatly hid this all important location so perfectly under a small section of wire harness that the normal eye would think that there is nothing under there.
Anyhow I hope you respond after my absence. I will think of more as I get time.
My 03 doesn't but my 89 does. ? I hammered out the grounds on the 03, thank you jag1. Now I've moved onto the other woe's this truck is throwing at me. Started with 117 codes got one left and another issue that isn't throwing a code. Fingers crossed.
There is often a lot of resistance to ground that occurs thru the alternator bracket. The alternator does not have it's own ground wire from case housing to a negative post so this all important ground is often found to be compromised by it running thru the rusted or slightly corroded mounting bolts. Even the heavily painted black surface of the alternator bracket with paint under the bolt head can help to insure a bit more resistance to ground. A well grounded alternator helps create a better balanced electrical system and helps reduce the damaging  AC voltage ripple to the PCM and other components. AC ripple can not only cause damage, but can confuse the PCM into some troubling issues.
