Headlight upgrade-- tips and gauging interest
- Replies 32
- Views 7.7k
Wild and Free 6 posts
dracozny 6 posts
dieselautopower 4 posts
Howie67 3 posts
I know my OEM headlights may be brighter then my ideas, but I can't see very well at night. Lots of us have poor lighting on our trucks, we spend hundreds and thousands modifying the truck, but most have stock OEM lights.Estimating cost at under $340 shipped for new sport headlights with a new set of bulbs and wiring harness. Would there be much interest in a plug and play kit with the sport lighting which uses a 9004 &9007 bulb at the same time in each headlight instead of just the 9004?Tipsto get better light you can:1. can use rubbing compound or degreaser on your yellowing lights to clear obstructed lenses2. do not use blue tinted lights or the "WHITE"' lights as the blue light mostly scatters. It looks lighter, but its mostly because it hurts your eyes.3. If you have relays set up correctly your voltage drop will be less leading to a brighter light.4. if you have lifted or modified your truck height re-adjust your headlights to be the correct angle.any other ideas...
