Can't find parts, fittings, or odd stuff? Great old school online catalog
- Replies 6
- Views 2.3k
CSM 2 posts
Mopar1973Man 1 post
Lone Watie 1 post
Texas CTD 1 post
Hopefully you do it yourselfers find this useful. I sure do, and figured I'd pass it on. I've used these guys for years at work. Nearly everything has a drawing, good specs, and honestly... they have everything. They even break it down by material, material properties, reactivity, etc. mcmaster.com Just last night I ordered the below items to redo my fuel pressure gauge. [TABLE=class: OrdDtlTbl, width: 858] [TR=class: OrdDtlRow] [TD=class: OrdDtlLnNbrCol, align: center]1[/TD] [TD=class: OrdDtlPartNbrCol]5220K61[/TD] [TD=class: OrdDtlQtyCol]4 Each[/TD] [TD=class: OrdDtlDscCol]Easy-align Brass Compression Tube Fitting Straight Adapter For 1/8" Tube Od X 1/8 Male Pipe[/TD] [/TR] [TR=class: OrdDtlRow] [TD=class: OrdDtlLnNbrCol, align: center]2[/TD] [TD=class: OrdDtlPartNbrCol]5112K61[/TD] [TD=class: OrdDtlQtyCol]25 Ft.[/TD] [TD=class: OrdDtlDscCol]Extra-flexible Nylon Tubing .093"id, 1/8"od,.016" Wall, Semi-clear, White,25'l[/TD] [/TR] [TR=class: OrdDtlRow] [TD=class: OrdDtlLnNbrCol, align: center]3[/TD] [TD=class: OrdDtlPartNbrCol]46425K21[/TD] [TD=class: OrdDtlQtyCol]1 Each[/TD] [TD=class: OrdDtlDscCol]Easy-set Needle Valve Steel, 1/8" Nptf (dryseal) Female[/TD] [/TR] [TR=class: OrdDtlRow] [TD=class: OrdDtlLnNbrCol, align: center]4[/TD] [TD=class: OrdDtlPartNbrCol]5220K31[/TD] [TD=class: OrdDtlQtyCol]2 Each[/TD] [TD=class: OrdDtlDscCol]Easy-align Brass Compression Tube Fitting Straight Adapter For 1/8"tube Od X 1/8 Female Pipe[/TD] [/TR] [/TABLE] I couldn't find the 1/8 line or compression fittings locally, (i've been trying for weeks!) and just ordered them from MCM. They are being delivered by UPS.
Want band saw blades for your DoAll bandsaw? Got them. Want hot water heaters that run off engine coolant with built in electric fans for an enclosure on your frac equipment? :ashamed:Got them. Want needle valves and 1/8 tubing? got them. Want a stupid little fitting that NOBODY else has and your local hardware guy says never existed? Done. Want some industrial tools or tool parts? got those too.
