- Replies 9
- Views 12.4k
Mopar1973Man 3 posts
dorkweed 2 posts
Wild and Free 2 posts
Ed'sTransmissionService 1 post
Just completed diag on 03 DR 3500 nostart, using TSB 14-003-06 RevA, as directed by Chrysler. Truck has 144K, no mods at all. In tank lift pump recently installed(by me). Truck has always had long crank time, scan tool shows actual fuel pressure slow to build to set point. Lift pump fuel flow exceeds minimum specs After diag, there is less than 100PSI during cranking. Unplugged FCA, no change(should have maxxed PSI). Performed hi pressure fuel flow test as directed by TSB, fuel flow was minimal. Result? failed CP3. No evidence of contaminants. My question is this: why do CP3 pumps fail? I've r&r untold # of vp44 pumps, and some common rail injectors, but no cp3 pumps. Just curious,,, Ed. Chrysler(my employer) offers no explanation.
