barfed up all my power steering fluid in the drive way
- Replies 5
- Views 2.3k
CSM 2 posts
Mopar1973Man 1 post
guesswho512 1 post
IBMobile 1 post
hey guys, i got a problem. late last week my power steering barfed up all the fluid all at once and had no power steering. after crawling under the truck, the only place i can find fluid is on the front of the gear box. all the hoses and lines seem dry. the hoses are in the factory slit-loom and none of the loom has fluid in them. it didn't barf it from the connection on the gear box as far as i can tell and the area around and below the pump are dry also. i looks as if it all came out from around the circle in the front of the gear box (but i don't see any holes, just fluid). i'm about to pull it later tonight, but is there anything i might be overlooking? any suggestion or thoughts are welcome. thx in advance
