- Replies 19
- Views 14.1k
oldschool 9 posts
MnTom 6 posts
Mopar1973Man 2 posts
YabbaDoo 2 posts
My engine stalls @ idle increasingly. It also did it on the highway when I backed off the throttle to switch interchanges several times already. It's been dangerous putting it to neutral @ 50 mph or whatever road speed I find myself to restart the engine. If I start it up cold and leave it idle, it will stall within 10 to 15 minutes. If I catch it floundering I've given throttle and saved it from stalling. When this condition occurred I've seen my fuel pressure steady @ 30psi before during and after. I have an Air Dog pump with a big draw tube with that kit. I also confirmed that the shut down solenoid holds steady. I changed out the fuel filters. In recent months the engine has been hard to start and getting worse. I've been writing that off as factory injectors @ 135,000 miles. I cant see how that it would be idling strong and stall on injectors. The stock automatic transmission finally hit an impasse as the lockup converter chatters and slips. I can't accelerate hard or tow anything in lockup. I can't see that failure stall the engine in park or neutral, but it's an issue. At this point I'm thinking it might be the injector pump. I'm really stumped. I could use help with this. Thank you
