Problem with new hard drive in Acer computer
I have acer computer and I replaced the harddrive cause the harddrive crashed. Well when I replaced it and hooking it back up. When booting the computer to install the windows xp it stops at verifying pool date...... What does that mean? I couldn't find another 160gb harddrive so i had to get a 300+ gb hardrive.
3200+ amd sempron,512mb,160gb,combo drive.ast160-us321h
  • Replies 46
  • Views 27.8k
it boots up flashes a blue screen then continues booting up then reboots at the black screen where the windows xp logos for getting ready to start windows and keeps repeating itself.
So you are seeing the XP logo? If you are, then the HD is working. Try putting the other HD in the Acer that is working, and see if maybe you got a bad HD, even if it is new?
Theres nothing on the new HD(300gb) cause I haven't got to that point on installing windows yet. It stops at verifying pool data. The hd(164gb) that reboots itself works fine in the t180 tower but when using it in the t160 tower it reboots itself
  • 2 months later...
Ok, I got the 300gb hd to format and install xp on the acer asphire t180 just fine. Just wont work on the t160. I guess this is a bad controller on the t160.
Well you just proved the T180 is fine and so is the new hard drive... But as for the other computer it does have a controller problem. You could buy just a controller card (SATA) and disable the on board controller and use the add on.
This the controller card a PC Repair Shop item or can I get it at Office Max or Staples? Well after talking to another tech he wants to try to put in the other computer. He thinks I didnt hook it up right. The old harddrive in the T160 was hooked up using the old style white 4 pin power plug and 1in wide black sata plug. Thats how I hooked up the new 300gb also. The 300gb hooked up in the T180 using the little 1/2in. wide black power plug and 1in wide black sata plug.
