Crossover Tubes
I bought new injectors and my engine serial number is less than the number websites say. Do I need new crossover tubes or am should I buy new ones cheapest I found was like 23 dollars each o rings iincluded.would it be cheaper at a cummins dealer?
  • Replies 6
  • Views 2.7k
98.5 my serial number is lower was looking at new crossover tubes and I couldn't think why they would be worth that much
On my 01 I changed the orings only. The tubes were fine.
What is the difference between 98-99 and later cross over tubes? This is the first I've heard of this, I installed all new o rings when I did my injectors but used my OEM tubes.
