- Replies 6
- Views 2.7k
Mopar1973Man 2 posts
joecool911 2 posts
Duwammer 1 post
TFaoro 1 post
I don't regularly check my brakes out because to be honest, I don't put hardly any miles on my truck. I rotate my tires every 5000 miles yet I’ve only put 4000 miles on it in the last 2 years.
I drive it basically only during the fall for hunting season and if it snows bad during the winter.
2 weeks ago a stop light changed and when I hit the brakes the antilock kicked in. I could tell something was wrong immediately. When I got home I found that the front rotor broke apart. It had rusted through at vents.
After fixing that a few days later I could hear a squeak coming from the rear brakes. I took those apart yesterday.
The caliper side has full pad wear. Yet the backside has only a spot with about 1/2 inch wear.
Why such different in wear on the backside.
Also is the drum portion simply for the emergency brake only.
