Rancherman Is A Yotahead...
- Replies 11
- Views 3.1k
rancherman 5 posts
Mopar1973Man 2 posts
diesel4life 2 posts
CSM 1 post
well, my experience with my new-to-me Toyota pickup was pretty good the first month. My son drove it from Montana back to Nebraska right after Christmas. This is a 1994 4x4 22re 5 speed. The 22re is a 2.4L 4 cylinder..
It had some timing chain rattling, and clutch was slipping some. Pretty much expected on 185,000 miles.
But, the body and frame is rock solid.
Then the head gasket let go..... sigh. Time to break out the metric wrenches.
I joined yotatech.com a forum site for similar 'yota' enthusiasts! ( I see AH641D lurking in there too!) And while there is a pile of info to be learned, it is painful in that site.
I wonder when a site gets 'stale' and there is thousands of members, (countless new threads on the same subject.... beaten to death...and still no REAL answer)
I read more posts in there that berated a new member for NOT 'searching'... time after time.
Gee, reviewing hundreds of 10 year old posts until blood ran out my eyes, reading posts with 'helpful pics', (which were removed by OP) and reading thousands of replies such as
"Oh, man, I got the same problem... I feel your pain".
" Sucks to be you"
" why are you pulling the engine anyway?"
"Fix it this way"
"Fix it THIS way"
or the classic....."Get a FSM..."
Lets just say, running a search on any dang subject almost caused instantaneous high blood pressure, heart burn, lower intestinal cramp, gout, possible epilepsy, tooth loss, and partial blindness.
Kudos for Mopar1973man. My medical condition is much better after spending time in here!
Meanwhile, I am in the finishing up stages of the trucks' mid life crisis!
I yanked the engine. You can't remove the oil pan to clean out the digested timing chain guide rail... without either removing the front differential, or pulling the engine. Out it came!
Replaced the clutch and flywheel. (new flywheel is cheaper than resurfacing old one)
New head and cam. (again, almost as cheap as rebuilding my old head)...
new oil pump, water pump, timing set WITH HD guides, and upgraded the injectors to 4 hole injectors.
I eventually pulled the trans to re attach to engine.. and went back in the bay as one.
In the finishing stages of wiring and plumbing, need to get back under and reattach the driveshafts and exhaust.....
Then, ON TO MORE EXCITING PROJECTS!
Weather finally 'broke' here, got up to almost 50 yesterday! Nice to be able to start a nut, without it freezing to a finger!
