Like a dead pedal but rolling coal?
- Replies 6
- Views 2.2k
diesel4life 2 posts
mulcher812 2 posts
Mopar1973Man 1 post
joecool911 1 post
So hear it is the best i can figure. I went out camping on 7-2 half way to our destination the truck started rolling coal like no tomorrow. I could fog out 4 lanes of traffic on a dangerous 6% grade, but if I could get on top of the RPM's it was fine. 1600 RPM's or better i made sure the overdrive was off, my T/C lock up switch was off. If I would just apply a very little amount of throttle and i mean less than 1/4" of movement it would start to haze then just roll black. All of the issues seamed to be with me hooked up to the trailer that weights in at 7600/lb. So I limped it home on 7-11. Then took the truck out for a drive well the issue is still there. Took it out to a buddies shop with the Snap-on Modis and found
Engine codes -
P0230 - Transfer pump out of range (AirDog 150)
P0602 - ECM fueling calibration error
not sure if i like this one...
P1693 - companion module error
Trans codes -
P0743 - Torque Converter Clutch Solenoid Circuit
P1765 -Gov Press Not Equal to Target @ not15-20 PSI
Cleared the codes to see what came back and it hasn't run right since. I have the 100hp sticks out and at the shop for a pop test and spray pattern check now but the P0602 and the trans code are puzzling me. If I'm missing something let me know or if i need more info I can do my best to get it. Thanks for the help everyone.
