My test gauge readings
- Replies 8
- Views 2.6k
ISX 3 posts
Lone Watie 3 posts
gassernomore 2 posts
I hooked up the geno's vulcan fuel pressure gauge this afternoon, and am getting 14.5 - 15 psi at idle, with a drop during normal acceleration to around 12-13 psi, and steady state psi at 45 mph (haven't been out on the highway yet) of around 14 psi. Are these numbers good/about what others are seeing with stock setup?Thanks.I'm still waiting on my fuel line for my isspro gauge, and was bored today, so installed the tapped banjo into the outlet port on the filter, connected the vulcan test gauge, zip tied open the needle valve so it wouldn't turn, leaving my test port on the filter for my permanent gauge. Still haven't ordered the big line kit for filter to VP.
