2006 VW Jetta TDI Problem
- Replies 17
- Views 8.4k
MnTom 8 posts
eddielee 4 posts
Wild and Free 2 posts
rancherman 2 posts
Hey guys, my son's car (06 Jetta TDI) has all the sudden lost power and I found out that cruise quit at the same time. I have VCDS and pulled an EGR code and an O2 sensor code. I pulled the EGR valve and cleaned it then put it back on. I get screwy readings on what it is doing. Most times at idle it will say 100.6% duty and other times it will say 15% duty. I checked the boost and the actuator comes up with the correct numbers. I blocked off the EGR for testing and it didn't seem to make much of a difference except now there were no engine codes. I should tell you that the fuel filter was changed a week ago. I tok it for a test drive and it would barely get out of its own way. I scanned it again and got an EGR code. I checked the fuel filter and it looks like brand new so I put the canister back together. Started it up and noticed it was way more responsive. Went for a ride and the first 150' it ran great then back to low power. I should mention that it runs real smooth so in my mind that eliminates the cam (which looks fine), compression issues or individual injector problems. The only thing that makes a diesel lack power is fuel and/or air. Since there is no smoke it points to fuel. I am stumped..... Here is the code I get:
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2925752
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64E94D3FA7A0153E1FF-8031
1 Fault Found:
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 215299 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:26
Freeze Frame:
RPM: 2856 /min
Speed: 56.0 km/h
Duty Cycle: 0.0 %
Voltage: 14.52 V
Mass Air / Rev.: 715.0 mg/str
Duty Cycle: 0.0 %
Bin. Bits: 00000000
