Question: Is it to hard to install a clutch guys I need to install a new clutch on this truck I just bought and a new flywheel since I can see from the bottom its got some teeth already damage and I think I am going to need a starter gear (were can i get the starter gear from?) . I have some experience fixing small stuff but I don't know if I can handle the clutch ,I have done the vp44 on my other truck and other small stuff like maintenance tranny and differential airdog install you know small stuff . I can follow instructions very well if somebody tells me how but maybe I need more than instructions ,Is not so much that I don't want to pay somebody to do it it's just that I want to learn how . Thanks !
  • Replies 41
  • Views 7.2k
Ok finally I got all the parts I need to install the clutch back. But I am confused on one thing should I install the transmission back with the bell housing or should I take the bell housing off and install the fork and the throw out bearing and then install the transmission ?
the 2001 fsm says:(5)Work transmission forward until seated against clutchhousing. Do not allow transmission to remain unsupported after inputshaft has entered clutch disc.(6)Install and tighten transmission-to-clutchhousing bolts to 108N·m(80ft.lbs.).
Ok so I got the flywheel and clutch and clutch cover used the alignment tool and installed the bell housing with the fork on it and when ever I was installing the transmission I did make sure the lift the fork up and was careful that it didn't came off the little pivot with the clip , the only thing I didn't quite understand was this notes " Mopars NotesThis is where I screwed up. I didn't lift the throw out bearing and pinched it between the input shaft collar and the pressure plate, causing it to mis-align the throw out fork and depressing the pressure plate fingers after bolting the transmission up. This cause the slave cylinder to bind up and blow the clutch master cylinder" . How do I check that didnt happen to me. O and now after all that here comes the oops I was bolting the bell housing and wanted to torque the just didnt know the torque specs and did them at 70lbs and one of the bolts broke :banghead: ,its one that goes right on top of the starter should I try to extract it , does it affect it ? also should I loosen them up or just leave them ? . Also when ever I was sliding the transmission in I couldn't get it to slide all the way in so I lined up the bolts and when they were able to grab the thread I started tightening them and thats how I got it to slide all the way in but I also didn't force them in I tighten them evenly and never forced one in what do you guys think?
" Mopars Notes
The throwout shaft will right close to the hole if done right you be able to see the pocket for the slave cylinder... If you messed up like I did the fork will be deep inside and hard to line up... Then the clutch pedal will go solid and not move...
Well since you broke I would take the time to fix it... As for bellhousing bolt I didn't bother to torque them I just made sure they were tight that all...
Normal... Because of minute angle and alinments it tough as hell to slide a transmission all the way in. But mine did the same thing... As long as the bolts tighten easy and did it even I wouldn't worry much...
if i had a dollar for every time that has happened...it seems if i try to hit the torque #s then i break bolts...sorry for your luck, but glad murphy follows other people too(i swear i thought he lived in my cab)
Ok so I am almost done with the clutch deal, I am bleeding the hydraulic clutch I got all the steps done I just got one question when I fill the reservoir do I take the little black plastic out and fill it or do I fill it with it in ?
i left mine in...but i had the clutch hyrdraulic assembly bled before it went into the truck. as in the reservoir was full before it was bolted in. i took my time as i didn't want to have to pull it out after just getting it in. i believe the pedal was the last thing i did. let us know when you finish it
Its alive ,I got the truck to turn on but the clutch its very loose did I did something wrong? I did bleed it did all the steps mike said well I think I did any clues?
What to do you mean by loose? :shrug:
Sorry I meant the clutch pedal is real loose and it is not working I have been trying to pump the clutch and I did get a few small bubbles out but I takes alot of pumping .So I got under and took the slave cylinder out and did a few strokes and I had someone look to see if bubbles were comeing out and I did had alot of bubbles come out so I continued doing it till the bubbles stop coming out and it hasn't changed very much just when I press it all the way in but very little but its still loose.
There is air in the system yet... The bad part is there is a loop above the resevoir and the air bubbles float into that loop and don't come out easy... Thats why it got to be done removed from the vehicle...
Ok I will take it out again and try it again, I think that was my error when I was bleeding it I left that loop were I had it set up .
when i bled mine....i filled the slave up and push air...connected hose, filled and bled...connected the master, fill and bled....by doing this i only bled it once, and didn't have to remove it after install. obvisiouly the air rises...so when bleeding, hold the escape path up and pump that slave's piston. as a cable guy, i have hundreds of zip ties....thats how i held the piston in while putting it back in the truck
Guys I got it ,I took it of and repeated the steps and it worked like a charm . Thanks for all the help! Now I am starting with some thing else the truck does not have drip bottle for the crancase vent hose and the radiators look pretty dirty there's a lot of grease they look black and wanted to clean them up . Should I start another tread about this? just wanted to know what was the best way to take them off and should I take every thing out. I am also planning on doing the custom crancase vent like I did on my other dodge.
Would this work for ya??? http://mopar.mopar1973man.com/personal/2002/crankcase-vent/crankcase-vent.htm
Took some pics check them out tell me what you think I also got some pics of the pwr steering pump and vacuum pump one of them is leaking was thinking of replacing may be the pwr steering pump.
