- Replies 10
- Views 3.2k
Mopar1973Man 2 posts
rancherman 2 posts
joecool911 1 post
03fummins 1 post
I add a can of Wix coolant supplement when I change coolant. But I've been told I should monitor the coolant ph level with test strips. Is this something that you guys do? Thing that makes me concerned is the bottom disc in my high dollar cummins thermostat fell off and was just sitting in the hole below the thermostat. Corrosion cause this failure? Was only in for a year or so.
