Posted February 9, 201015 yr Hello again,I noticed the 2-3 inch rubber line from my hydroboost is starting to split. Is this high pressure hose or what is recommended to replace it? Thanks
February 10, 201015 yr Owner If its got hose clamps then its low pressure... If its got screw in fittings (flare) then its high pressure...
February 10, 201015 yr Owner Then its a low pressure return line just stop by a NAPA store and get a chunk...
