Looking for Staff Members
Anyone know of a place that sells aftermarket or even factory towing wire harnesses for trailer lights, besides the dealership?
Edited by 440Rat
  • Replies 8
  • Views 1.9k
I think any trailer supply would have what you need.
I did make my own rv umbilical cord that plugs into the truck out of heavy gauge construction cord and rv ends. I just ran it inside some soft rubber automotive heater hose for the outside sheathing and protection of the wires..
iirc LMCTruck sells them...  or Reese hitch company iirc does as well.  if your looking for a kit that adds trailer brake functionality the dealer kit does this and isnt too bad to install yourself.  i had to add it to mine to remove the PO's hack job wiring....
I'll have to check out LMC or Reese. The harness thats on the truck has been modified, and doesnt work worth a darn.
check your local farm supply... such as  Tractor supply,    I believe  in your neck of the woods  would be called  'Mills Fleet and Farm"
The closest Mills store is about 2 hours away. There may be one coming soon to our area though!
Matt, any time you want you can come look at mine and see how it was done.
Tom I might take you up on that. My FASS showed up yesterday, after I get it installed the trailer harness is next on the list.
Sounds good to me!
