Grid heaters not working since high idle cold start enabled at dealer
It seems since I brought my truck into the dealer for the 3 cylinder high idle cold start enabling my grid heaters haven't worked. I see the wait to start light come on but the voltage doesn't change. I have to plug it in even at 0'C now or it won't start. Lots of white smoke for the first few minutes when I do get it running . Could there be another problem I'm missing maybe? Can a dealer possible program stuff to mess up or maybe accidentally delete my grid heaters somehow?
  • Replies 12
  • Views 3k
Any codes? sometimes when working on truck I knock the little wire to grid heater relay loose and they wont work. Of course when I do that I get a code.
These codes showed up in the order as follows. PCU 0500,1694,1693. ECU 0234,1693.
There is a smaller waste gate boost elbow installed.
One morning I had the check engine light stay on but it was gone when
I fired it up again.
What are the perameters for when the grid heater should come on and off
The P0234 is probably cause by a heavy foot and the smaller boost elbow. P0500 I heard is from spinning the tires and not really moving, not sure if that's totally true. But with the torque of these truck on icy streets it happens a lot .
Some times you get a condition where the rear axle is spinning but the front axle isn't moving then the ABS computer gets confuse and trips the P0500 code because how can half a truck but motionless and the rear half is moving 25 MPH. ABS computer can't compute that.
So I took it to the dealer this morning because I wanted them to check and make sure they never set something off. They told me it was my relays and it happens a lot ... I checked for codes as soon as I got back in the truck. Now it says PCU 0500,1694, 1693 and ECU 0382, 1693. Why wouldn't that show up before I gave it to them?
