vp44 gear difference 98.5 to 01
I want to know If the vp44 gear is the same in 98.5 to 01 , and also if all the gear in the 98.5 timming cover is the same that 01 have
  • Replies 16
  • Views 4.2k
As far as I know they are all the same. The only difference is the key itself that needs to match the pump.
Ok because the truck is a 01 that have been swap with a 98.5 and the truck is in limp mode because off the diffenrence cam 01 and cam and crank sensor 98.5 . So i want to buy a 01 block with no turbo manifold and vp44 so i want to put all my stoff that run the 98.5 on the 01 that deserve to be in the truck
Only a cam gear from a 01 and the cover and my truck will run fine? Because i heard people talking that this those not work amd that the hole cam *** to be swap
As far as I know all of the 24V cams are the same. The only difference is the gear, which has the tone ring for a sensor in 2001.
Did you read my article?
You will need to get the gears pressed on & off, so you might as well swap cams, or it is a good time to upgrade a cam if  you like.
Ed
Oh ok its less trouble to get a 01 block and putt my vp44 on it
I agree with Ed. You will need to pull the front end all apart for either a cam or a block swap, but I would swap the cam.
But if i change the cam i need timming cover and the 01 cam but is this a big jobs or its easy to change the cam because i dont want the truck to have probleme after changing this
Yes, you would have to change the gear housing. I would think you can get a performance cam, replace all of the parts & still have it quicker & cheaper than swapping the engine.
Do you still have the donor truck?
Ed
No i did not get the donor truck. Ok i gonna check for a cam and gear housing . But you think its cheaper to change the cam to replace the engine and sell mine that its in the truck
Well, it could be a wash that way. I am just the kind that would take the 98.5 engine & rebuild it & then swap everything over, while using the 01 engine as a temp, but that's just me. My wife tells me I am a hoarder.
You may find a housing & cam from a blown engine at a salvage yard on www.car-part.com It is also a good site for cross referencing what parts fit, as they use the Hollander Interchange system to only give direct crossed parts. You may also check diesel shops for a used housing that is left over from a P pump swap.
Ed
Edited by Yankneck696
Okey because i check and a after market cam is like 700$ and a 01 block i have found one to 1250$
Not a bad price. Is it confirmed an 01-02? Private seller or salvage yard? Any warranty? Any documentation of miles?
I would check it out & throw some bearings rings, a hone job & a gasket kit in for good measure if everythng measures out.
Ed
Yes confirm that its a 01 and its someone that doing mecanic of cummins for 20 years but for the warrenty i am not sure have to talk with the person
