Edge Comp Reset?
Hey guys. Can someone tell me how to reset the Edge Comp. I think there was a post somewhere that Mike told me how to do it but I can't find it.
  • Replies 6
  • Views 3.8k
Not sure about a "Reset" per say but you can set the sublevels 1-5 within each main level 1-5 . Been a while but I think you need to hold both up and down arrow buttons for a few seconds until the LEDs start blinking then use arrows to adjust sublevel, it has to be done in each level, to set you just use power button and turn it off and on again.
Thanks guys. By the way Mike, that was me that messaged you over on CF. As you can tell, whatever happened has worked itself out.
Edited by rlane547
Hold the power switch for 3 seconds and release put you in sub-level mode.
To reset the Edge Comp just try the key off. Then next power cycle it boots back up.
One can't "Like" your posts?
Thanks I knew one had to hhold one button or a combo of buttons, been over a couple years since owning it.
Hey Bill, I cant "like" your posts either.
