- Replies 5
- Views 2k
Mopar1973Man 2 posts
c farmer 1 post
Ilikeoldfords 1 post
lrhull 1 post
All winter I've had the dreaded steamed up oily windows from running my defrost. I just assumed it was the heater core and that's going to be a bear to change. However a friend at work with a 01 cummins has the same problem and thinks it is the ac leaking. We both have some thing leaking from the floor vent. I thought it was dirty antifreeze but he says it's more oily coming from the ac. Sometimes I think it smells like antifreeze but then yet it doesn't. He put in 2 cans of 134 and a stop leak to see if it fixes it. So I remembered I had to charge mine twice last summer. so it was pushing 60 degrees today so I tried my ac it never got cold. So should I try some stop leak or go right to taking out the dash and changing the evaperator and heater coil? Anyone else have the steamed up window problem?
