Other Engine build, 340 6v
- Replies 4
- Views 2.5k
Mopar1973Man 2 posts
Wild and Free 2 posts
Anybody with old mopar experience? If so, feel free to chime in.
I am going to be in a position in the next year to start work again on my long neglected 70 Cuda. I've owned the car for quite a while, and its sat in the barn at home awaiting (as my dad put it) "time on your part or interested grand-kids!" Well, I may just have time starting spring 2016 and I am not ruling out the kids... So, lets discuss engine options.
Overall, the car is an original 318 auto sublime green car. I have the rest of the parts to finish the car into a power bulge and nearly correct clone of what a 6pack non AAR cuda would have been. See photo below of what it looked like when I drug it home. It has since been stripped and is awaiting patch panels and body work.
It has been converted correctly to a 4sp car with all the correct parts. 8.75 489 case rear end and still has the small block K frame.
I have several A833 4sp transmissions to choose from that I've collected, and plan on trying both the old ball and detent style and newer style out.
I have the parts to build a 340-6 pack (non T/A block & heads). I have two third members, and plan on keeping a 2.73 around as well as keeping the 4:10s around for track use since I have both now. I will likely end up with 3.55 final drive.
The engine block will likely be a 68 or 72 .30 over 340 casting with steel crank. stock stroke. Stock reconditioned rods. I plan on a set of KB Hypereutectic flat top pistons.
I have a set of X heads as well as several sets of J heads that I plan on starting with and doing a few iterations of porting until I finally give up and buy a set of Indy or Edelbrock heads. With the factory heads, and allowing for the smaller chamber Edelbrocks later, I will have to run with a lower 9.4to 1 compression on the Stock 70cc heads, but will up that to about 10.2?ish to 1 with the 63cc Edelbrock heads. (all assuming stock deck height) I would like to push this to about 10.8-11:1 with proper quench and cometic gaskets in the long run.
The cam I am planning on experimenting with and contacting a few folks. The car is not a daily driver and I want it to be in the power band between 3000-6500+. As the cam and heads are going to be a bit of an iterative and fun process, I plan on trying some different stuff out. Also, keep in mind it's a 4sp car with zero vacuum components. It even has a manual foot operated windshield washer pump.
"would be nice" Items will be a new MSD vac & mechanical ignition setup as well as new metering blocks for the outboard carbs so I can easily jet them.
So, all that said. Any thoughts?
Edited by CSM
