From the album: Mopar1973Man Landslide
Driveway is finally clear and we can access the house normally!
Yeah I'm finally getting this cleaned up and can focus on getting my driveway back. As of right now the driveway is rough but accessible for vehicles to the front door. After I clean up the trash pile we will have parking area for all the vehicles here on the property. I'm racing against winter time to make sure I can keep my driveway cleared and open. The videos are while I was digging for the shop stuff and Mark personal stuff, if I got lucky but most everything in the house and shop was crushed by heavy slabs of concrete. Finally, I got my driveway cleared in a rough method. It has been long days and a lot of diesel fuel for digging like this. I've had to double-stack all my dirt and debris pile against the mountainside. This is only a temporary place for just the wintertime. I've still got to rebuild a shop at some point so I can even maintain my own vehicles. The driveway is clear but I've got a huge trash pile to sort out, hopefully before the snow comes. Take the wood and move it to the lower yard to be burned this late fall.
Help me build the perfect motor
@Mace could you build an article for the electric vacuum set up?
Basically, the pump section pulls out of the reservoir, and there is a large o-ring. As for the pump vanes, I've never opened up. Rest is just o-rings. Be sure you can get the o-rings first before opening. I would check with Blue Top Steering for pump and steering box supplies. https://bluetopsteeringgears-com.3dcartstores.com/
ECM failure?
Double check the black/white wire that grounds behind the starter. This is the ground lead for the lift pump and fuel heater. If you bump the starter there should be power on the the other wire in the plug but the ground might be dead.
Pilothouse/RAM3500 build
Closer to paint. I dying to see the final product.
Power Steering fluid should be changed every 30k miles. You can pull the reservoir housing off so you can rebuilt most of the power steering pump. There might be screens inside. Make sure to get a new o-ring first. Vacuum pump seal you can get for like 20 dollars at Cummins supplier. I get mine from Rocky Mountain Cummins super cheap.
Do I need to bleed fuel system again?
Last time I bought a roll of 1/2 inch line from DAP. Can't remember the price but it was about 20 feet on the shipment. Mine just found out in the landslide the other day.
So you have the JIC type push loc fittings? Still, you should check the mating faces to make sure there is no grit or damage to the mating faces. I just had a hard start on Beast just yesterday, and my head is already processing. Suction side never leaks out but will continue to allow air in. Yeah, I've got the same fittings as well. The mating face if damaged or rusted, will typically start to leak (loose prime or leak outwards) Thor on the other hand has the plastic quick connects. On these you can grease the smooth bore tip and the grease will aid in sealing.
Recent upgrade
Same driveshaft my 1972 Dodge Power Wagon had... I'm assuming there is a grease zerk on the other side of the stub? The issue I had back in the day the spines wear down if you don't keep up with the greasing and that seal for the spline. My old 1972 had a unmarried transfer case and that short shaft was wobbling from a worn spline. Learned a lot about the old school spline shafts.
Down and Out
No. I still had internet and cellphones. I was unable to reach mopar1973man.com solely. Took about 4 days for the broken backbone to straighten out.
Down and Out
Man, when it rains, it pours. Last Thursday, there was an internet issue beyond my reach. What would happen is try to access Mopar1973Man.Com website, the site wouldn't respond at all. Making matters worse that I attempt to reach the hosting company, and the same thing happens. No response at all. Yeah, panic sets in for a bit, but after making a call to the sales team, they clearly could see the server was running, and pages were loading normally. My problem was just after the ground station of Starlink, there was a breakdown in the backbone of the internet. Just had to wait and be patient for the internet to return to normal to get to the website. I've been right here at home for the week and lost internet connection to the website for 4 days. Beyond that, I've been spending most of my time cleaning up the yard of all the dirt and debris. Most everything I had has been crushed or damaged in some way. Found my chainsaws, both under a huge chunk of concrete wall lying on top of both saws, and they are just beyond repair. Found a full-size front-load washer no taller than 3 inches, mashed flat. Most everything had mud, and water ran through it. Electrical stuff might be best to just replace. Then the other stuff was crushed by the pure weight of mud and trees. All the downed trees have been pulled out are leaving the yard in trade for usage of Dischinger Family equipment. Personal health note... My sleep apnea test came back. Not good to find out my oxygen levels are dropping into the 70's percent range as I sleep, not good. Thankful that the medical team informed me of my low oxygen levels during my ostomy surgery. Suggesting I talk to my doctor about taking a sleep study, it took quite a while to get this done. For the last 4 nights, I've had my CPAP and have been getting good sleep and staying asleep the entire night. Trying to split up time for everything is nuts right now. Then when you wanted to work on the website and loose connection to the website and hosting company. Yeah been a huge hang up this week and hopefully we can get back to work.
Water methanol for mpg.
Waiting to see it running. I'm really curious to see the outcome of your idea. Sometimes the crazy ideas teach you something along the way. (2 cycle oil, crankcase vent pipe, etc.)
NV4500 parts
@Doubletrouble he was the last one I heard that rebuilt his transmission. He would be a wealth of insight also with the tools you need.
Server and Workstations
Been a moment. I've been busy building these 3 machines. SERVER Now, as for building a server, this is my true first Linux Server I'm building. I've created plenty of desktop and laptop Linux systems. Now, let's roll back the clock to the good old days of Microsoft DOS 5. Starting a server is very interesting. The entire install is very strange, being we are all used to working with a mouse and keyboard. 😋 Now drop the mouse and just a screen and keyboard. Yup, there is no graphical environment here now. No mouse to use or icons to click. You have to know what you are doing to get one fired up. I installed Ubuntu 24.04 LTS Server Edition. Then installing the network management software took a bit to wrap my head around, be we are running a live server here at home. This machine will have several tasks to do in regards to the live website server. Then handle all the security cameras and store the video footage. It will be a large cloud server for backing up all our personal data and business data between workstations, laptops, and even cellphones. WORKSTATIONS The two workstations are high-quality machines for handling all the website work, video processing (KDEnLive), photo processing (GIMP), and much more. These workstations will bind to our cellphones. This will allow us to keep right on working, being text messages will display on the monitor. All 3 machines come with 2.5 GBit connection on CAT6 cable or WiFi 7, which is capable of a lot more. The main WiFi in the house was upgraded to WiFi 6. A huge improvement is speed. 4TB M.2 SSD Drive in each workstation. Storage of files and data is no issue now. The server will be tasked with making backups as we sleep at night.
Spring is fast approaching!
I'm cancer free. Still having minor issues with my kidneys. Toss in sleep apnea. On May 29 2025 my shop has been destroyed.
Landslide updates
Lot of you might be a bit upset with me not being available at the drop of a hat. Sorry! Since May 29th, my life has been turned upside down, and been dealing with all kinds of issues. For example, I had a brake malfunction on Beast and was attempting to fix the issue with limited tools, royal pain in the tail. Thor has an issue right now with the injectors (again) and is short on time and short on tools to really dig into this. I've had some luck and got another family involved, and was willing to loan out their Bobcat track hoe so I could get this huge dirt ball off my driveway. I know there are a few of you asking about donations! Yes, we have a donation page up, and every penny counts now, so I can replace tools and equipment lost to the landslide event. LANDSLIDE DONATION PAGE - Also available in the normal menu. I've now created a full album of photos from the time of the actual event and the current status of what is going on. I'm going to keep updating with photos in the Mopar1973Man Landslide album. Stay tuned, a lot more to come! LANDSLIDE PHOTO GALLERY So if you are really wondering what I've been up to, this is most of my effort currently. I'm focused currently on clearing the driveway so we have access to the remaining home here. Mark and Hachi, my friend and his dog, were living in my guest house and helping me through my bladder cancer. Right now is access to the house is much more improtant being @Tweety Bird has a fused ankle, then myself with the ostomy bag; neither person should be walking across snow and ice to get to the house. My remaining time in the evening has been working on getting the work stations up and running and then build my local server here to manage data backups of our workstations, the storage of video footage from the security cameras, also the server that manages the network switch and provides a secure internet for the household. There is a few photos I want to bring to people's attention. These are from the shop floor, which I dug down to, and shooting photos from the shop. You are looking at the alleyway that I've managed to cut through the 4 to 5-foot-tall landslide. Thanks to the Rupp Family for the use of their Bobcat Track Hoe, then thanks to the Dischinger Family for still coming by and doing the advance moves of the very large trees with the trackhoe. Yup these trees were all removed from the landslide. Now, to show the forces this landslide had. There is a photo below of the large double-door refrigerator that was in that house. When I found that I was shocked to find the refrigerator. It was tipped over on its face and the pure weight of the mud and trees crushed the refrigerator to 3 inches tall no joke! You can see the remains of it here in this photo. Top of the stack. As for the 2 new workstation computers and the new server. I've managed to get my workstation up and running, @Tweety Bird her workstation is up and running, but there is a minor glitch with the motherboard not being willing to use the new video card and its abilities. I've got to investigate why yet. As for the Ubuntu 24.04 Server, this is sweet. This will be a true headless computer with no monitor or keyboard. Even if you have a monitor and a keyboard, you can only log into a textual operating system. No mouse or graphical interface at all. Extremely lightweight, server, and super quick. Currently, there is 16 TB worth of storage on the server. I've made a mistake in ordering the two old-school mechanical drives instead of SSD hard drives, as the mechanical drives won't fit my server case. There is 32 GB of RAM, so there is a lot of room for server software, which I'm still considering a lot of different stuff for backup routines, etc. So this is the environment that I'll be working in, and all the workstations and server will be firewalled from the outside world.
