Unit bearing puller
https://www.tiktok.com/t/ZTRvs1hJJ/ You're welcome.
Here Kitty Kitty Kitty...
I've got bears every year. Just had a skunk 2 nights ago. Deer up close and personal. Mountain Lions, bobcats, cougars not often but do come around. Make sure your trash cans are inside. Trash and food scraps attract animals if they are hungry enough they will continue to hang around. Blackberry vines should be removed sadly you now provided a home and protection to any animal. Something I'm getting rid of on my property to not have they mess of issue. Animals always go for blackberries food source and protection.
Having my VP44 Rebuilt versus reman/exchange
For example Blue Chip is not a certified rebuilder. PSG is used Moving parts are replaced Not ran on a test stand and calibrated
Why I do not like wide tires
I've had my encounter last June when I went over to Seattle for Jake's graduation I had a Ford spit a front tire and played Dodge the tire on I90 heading to Seattle. I know they look cool but not cool Dodging tires because of cheap spacers and improper geometry wiping out the front ends.
2nd new VP44 installed, sounds great, whiteish grey smoke and no boost indicated. No codes.
Could of got a steal on a gasket set. https://store.mopar1973man.com/mahle-ms12435-intake-manifold-gasket-set.html You guys need to check the store more. Even got MAP sensor in stock. Boost leak will not affect smoke. Injectors would be more of a cause. Possibly a crushed key or the key fell out during install of the VP44.
Death wobble issue rears it ugly head again
I'm thinking of using BBs in my tires. Cheap have weight and will self balance the tires.
98.5 crank no start
You still need to look into the communication error problem.
Here is why I don't like wide oversized tires on any vehicle. Take notice this Chevy truck loses the entire brake rotor as well. People don't realize the stresses that oversized tires do to steering and suspension as well as wheel bearings. This is more common than you think... Consider the legal side after this accident just because someone wants their truck look cool...
Personally, I still think it starts at the tires and shocks. Yes, I've seen several members without a steering damper with no issues.
Pilothouse/RAM3500 build
Wow. This is a long project with lots of home-crafted solutions. I'm still patiently waiting to see the end when it rolls.
Revision 027 pumps if built at a Certified Bosch should come with... Timing piston sleeve is steel. New PSG All moving parts replaced. Ran on a Bosch 815 test stand for 3 hours PSG will be flash after passing all test.
New addition to our family
Kong are really good dog toys. Hold up very well. Stuff animal toys yeah even Loki just destroys them quick.
98.5 crank no start
P1694 code is communication problem. Without looking I would say ECM. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/obdii-error-codes_94/p1694-no-bus-message-received-from-companion-module-r139/?do=getLastComment&d=4&id=139
I've installed Bilsteins on other vehicles I'm not impressed by the performance. Feels stiff and harsh ride on the 2nd and 3rd Gens. Just my personal 2 cents.
98.5 crank no start
It's still possible there is an issue. If the wait to start is flashing like he said in this morning phone call that means something is wrong. I suggested checking power and ground pins on the ECM and contact Auto Computer Specialst. Yup he called this morning for help.
98.5 crank no start
ECM issue. The wait to start is directly hooked to the ECM and one of the first instructions at boot time to control that light. If you didn't yet I would contact Auto Computer Specialist.
Just a heads up Napa NCP line typically is Moog parts.
Manual to power window swap
Kind of figured. You'll need to most likely hit a salvage yard for the wiring.
Internet Provider Failed...
Well, I finally had enough of the unstable internet here at my place. I made a call to Ziply and talked to a technician about my Internet dropping out and how I could be on a call with a client and then the phone call will start dropping out. Ziply technician said she would send out a technician to verify the signal and figure out what is going on. So the next day the technician comes out to the house. We had a nice long chat I will admit I know this guy very well. He informs me that all the wiring is in good order and no reason I should be dropping service. He also informed me some of the new equipment is already in McCall just waiting for it to be switched over. Well after that visit basically to tell me everything is in order and working. I placed another call this morning to Ziply and proceeded to ask for a discount for service being they can no longer provide the speeds I'm paying for. As I explained to 4 technicians about this it is a "breach of contract" that I'm paying for a service they are not capable of providing the speed and service I'm paying for. Typically in the evening, it gets so bad that I start dropping calls for my business phone (Samsung / Android) on Verizon Extender. My cellphone pager for the fire dept can't work unless there is a good WiFi signal which there isn't. As displayed on my router... Link Speed: 26558 / 1914kbps After having a long heated conversation with these 4 Ziply Technicians the best they can do is give me a one-time discount of 20 dollars off my bill for 3 months. This not going to fix my service or keep me on the internet. I even brought up the fact I could start calling the BBB and attorney and see about getting money back or a good discount. Again I more or less hit a wall and the final technician couldn't do anything more. The problem is typically people call me after work in the US. This means the east coast is 2 hours ahead of me and I can handle their questions and issues. But by the time Mountain Time gets off work, my internet is down to crawl and I can't have a long phone call without it breaking up. That's another reason I've not been posting videos because the upload speeds are horrid and slow a 3-minute TikTok can be over 30 to 40 minutes. Just like populating the store with products is slow as I wait for the server to respond to each item I place up in the store. As you'll see below my server is A scored and fast to respond. So I'm going to continue to stumble through this slow and broken internet till I can get StarLink. The biggest problem is the initial start-up cost of $600 for the equipment and then the first month of service. Now I know a friend just down the road a mile and played with his setup and I love the solid internet he has from StarLink. So as soon as the store gets running I'll invest some money into dropping Ziply and switching to StarLink.
Even a Blue Top will do the same. I've got the quick ratio box. But... You can rebuild a stock OE box for about 70 bucks and make it tight too.
Beast - Misc small repairs
You know my acronym for F O R D? For Only Retarded Drivers. If you are dumb enough to buy a Ford you deserve either case...
Absolutely...
Loki is similar in that respect. He will follow his family around and watch closely. Like tonight I went to town to pick up Jake from work and Loki was right at the door alerting me to the fact someone was coming to the door. Once he can see us his alert turns to a wagging tail and happy to see us. Dogs are wonderful companions. Some day ill most likely gets me another Dobbie or German Shepherd. I like good working dogs that are large enough that makes people think before just coming in announced.
Cyl injector lines loosening up over time- is there a torque spec?
In all the years of doing injectors, I only left one line loose on a member's truck. I never measure line torque. I just go by feel. If you crack a line loose while running you see the required torque to make it seal and run. Then I just add a bit more and that's it.
