1slow24
Everything posted by 1slow24
  1. Thanks very much will definitely look into that!!!
  2. Ok so messed with it for an hour or two again tonight. Somehow I got the headlight switch and heater control lights working. Kinda leads me to believe its in the cluster itself?? I need to invest in a wiring diagram. Any recommended ones to buy?
  3. Awesome will check tomorrow
  4. That plugs into the back of the cluster. I figured I would start there lol.
  5. Hey was wondering if someone knew which pin was the hot for the dash lights?I'm tearing my dash out tomorrow and want to finally get this issue fixed. Any help is greatly appreciated!
  6. No they are not junk they are just a part that has to be watched. See if it has had a new injection pump put on it, and a lift pump, then last but not least a fuel pressure gauge!
  7. Coming along great!!! Around how much will you have in it selling your old stuff??
  8. Mine sits at 20-21 and at WOT it will maybe drop a pound. Unless I'm under a 1/4 tank (rarely) and it will drop to around 18
  9. Factory size lines?? Did you pull all the parts or buy them?
  10. Let me know what you figure out, I have the same problem with mine!
  11. Awesome what setup you plan on running? I may do this as a winter project to mine
  12. Hey I was wondering if anyone had the part #s for spicer non-greasable front and rear universal joints? Any help would be greatly appreciated
  13. 1slow24 replied to LT smoke's topic in General Conversations
    I'm down in southern ohio. Just about smack dab in the middle of the state.
  14. 1slow24 posted a topic in Introductions
    Hey guys on a few of the other forums and got lead here. Great info and write ups on here lots to read and take in!! Hope to be able to help out a few on here!
