Everything posted by Mace
ECM failure
Well the girl is starting to come together. My Nations 180 showed up today and I’m going to install it on Monday. I’ll make sure to clean all the mounting surfaces to ensure a decent ground. My ecm & pcm are in @Tractorman care and he’s forwarding it to ACS on Monday as well. I’ve installed my Airdog 100-5G during the week. Quite happy with the install (I’ve deleted the oem filter housing now). I put a 6.7 wif sensor in the water separator and made a jumper harness from the engine harness wif connector so I can retain that. I’ve lost the heater side since I couldn’t find a filter with a heater element in it. One thing I noticed in the airdog harness is it uses the oem lift pump connector for the relay trigger and already comes with a diode suppressing relay. I removed the oem lift pump & plate and am waiting on a Fleece block off plate to cover the hole. During my adventures in wiring down on the engine harness I was leaning on top on the engine and accidentally broke the dipstick handle off. I see they discontinued it and have the “new style” dipstick & tube on order. The old tube came out surprisingly easy. Just a note about my GDP Fuel Boss removal. I ended up breaking the crank side pulley wheel to gain access to the harmonic bolts to remove the adapter. Those set screws are a PITA to get out after many years of exposure to the elements. What a nightmare it will be if you had to replace a crank seal or something all because the set screws don’t want to come out. If anyone is interested in buying my old kit I got a deal for you. You’ll just need a new pulley wheel adapter (I’m sure you can buy one from GDP) and new 3/8” hose.
ECM failure
I completed every aspect of the wt mod as written. That ground is soldered now.
ECM failure
I ordered a Nations 180amp alternator. When I was moving my truck into my works yard the rpm was going crazy and the “check gauges” light came on. I hope other components arent getting killed by this thing.
Power Steering Pump / Vacuum pump Conversion
I used the SMP from Rockauto originally. It was slow or so I thought. My vacuum switch recently died at the same time so I replaced them both and my EB is quicker now. 1-2 second delay turning it on and maybe 2 delay switching it off. Noise is the same I find.
ECM failure
I have the 6spd but I’ll look into Nations. Had a good run of 24 years but I guess it’s just 2nd gen luck! I did the wt mod 2 years ago I never had issues up till then but it seemed like a good idea to just do it.
ECM failure
It’s worse now. The rpm is surging pretty bad, enough that I can’t drive it safely. My current alternator is 5 years old now maybe I should throw a new one on. Any recommendations on that or will a parts house one suffice?
ECM failure
Anything I can do to prevent it from happening again? I read the alternator can cause this?
ECM failure
Maybe some of you gents can help me now? Truck starting getting some bumpy rpms this afternoon. Drove it a bit and now it’s limping along with erratic idle. CEL on now. Codes I have: p0606 p0113 p0118 p0121 p0123 I read an article from here with someone with the same issues/codes and it was an ecm failure. I have the WT mods done, batts are clean & tight. I’m sitting on the side of the road right now so I thought id drop this topic. Any recommend ecm rebuilders?! Thoughts?
I’m glad it worked out. What a difference Ive had to replace my electric pump recently already as mine died. I replaced it with a Dorman one. See how long that lasts…
GDP Fuel Boss
Here’s another idea: I’m looking at an Air Dog 100 5G for simplicity. I like how their kit uses the ecm lift pump connector for its relay trigger. I suppose I could use a relay with a diode suppressor to protect the ecm. So it’s either a dedicated draw straw or a tank sump to supply fuel to the AD. I see on AD’s website they have a plastic 3/8”connector to 1/2” barb fitting. Could I use the oem 3/8” fuel module supply port to fuel the AD? It would be cleaner, I already have a draw straw in the tank for the Webasto. Edit: Nevermind, their kit does draw from the oem module supply fitting.
Engine heater
I said that too for the first 22 years of ownership, now I’ll never own anything without one.
GDP Fuel Boss
I really like that Fleece in tank powerflo pump setup. Pricey though
Throttle Assembly Re-location Mod
Timbo doesn’t make an apps. He resells a Williams Control one, I made a post about this explaining it as I feel it’s huge scam. He even claims on his website as to what he sells. I listed the part number for everyone as it shouldn’t be a secret. Apps in the engine bay is an outdated idea. They don’t don’t do it anymore. They moved it from the engine to underneath the driver battery on later 3rd gens to now it’s a pedal combination. Where it’s safe from vibration and the elements.
I’m ocd when I make harnesses I can not have splices or unions. John, you can buy Duetsch terminal pliers for crimping the terminals on and avoid splices/unions. Your apps is still in the engine bay so it’s susceptible to moisture and the elements.
I truly believe that the amount of apps sensor failures are because of the vibration they absorb being engine mounted. Ram eventually went to a pedal apps setup in the later 3rd gens. Well done, looks good!
Greeeting! :)
I never noticed that noise. I mean we pretty much drive farm tractors with rocket ship engines. I was just happy if it started in the morning
Engine heater
Thanks! It’s worth its weight in gold. K19, there’s an engine I haven’t seen in a while. I still miss the 444 and the N14. Times have changed.
GDP Fuel Boss
I’ve had my fuel boss on for years. No issues other then replacing dried out cracked rubber fuel lines over time. I want to delete my oem fuel filter and run a frame mounted setup like GDP’s stand alone filter w/ heater. By using a FS19596 filter I can have a connection for the oem wif sensor. I also want to delete the oem electric lift pump. Has anyone here bypassed the stock lift pump and ran straight mechanical? And if so how did you plumb it? Im thinking 3/8” line from tank to filter, then to mech. pump then to VP44. But I need to regulate the pressure with the bypass valve so should I tee it from the return side up to the vp? The return goes back to tank with that filler neck fitting. Thoughts?
Greeeting! :)
I’m glad your into this as much as I was If you make a better bracket let me know I’ll buy one from you.
Engine heater
I live in Canada. And because I do I got really tired of plugging in my truck during winter in hopes it’ll warm it up enough for easier cold starts. I recommend everyone running of these. Couple years ago I installed a Webasto coolant heater. I’m sure you all know how they work so I won’t explain it. I run an aftermarket bumper so I mounted the Webasto bracket to the old oem support bracket in the passenger side so keep it close to the engine as possible. I plumbed the water lines to engine via the water pump housing lower outlet (where the trans cooler fitting would have been if it was equipped). The pump is located up by the R/H battery and plumbed into the firewall heater core inlet. I’ve deleted the pipe that runs under the turbo to clean it up. I’ve run the electrical & fuel line through the frame rail attached to various points with p clamps to keep things in place. The controller is in the glove box and I can control it via an app on my phone for programmed starts. Stay warm!
Greeeting! :)
The pin comes out. I literally put a pair of vice grips on it and it threaded out with a little force.
Greeeting! :)
I don’t need a manual high idle. I was saying that mine is enabled by ecm for cold weather. I don’t run a pto or anything where I need to control it. I don’t even have it tuned. Stock power with RV275’s :D
Greeeting! :)
All I did was put my apps on the new pedal assembly. I’m not sure how many rotational degrees it is but it worked the same as the old bellcrank setup. I have full throttle 0-100% when I tested it out of the truck. I would rather the apps not bottom out on each side of its sweep. Keep me updated. I don’t have a high idle solenoid I programmed the ecm per TSB 18-019-01 for cold weather high/3 cylinder.
Upgrades
Well I’m swapping in a NP271D in soon with the Ford fixed yoke on the back, with a matching 1 piece driveshaft with 1480 ujoints (ours use 1410). Those are all ford ideas they run on their trucks. Im not pro Ford I just like some of their ideas. Dodge seems to cheap out on what they call a “heavy duty” pickup. I shouldn’t compare to a 24 year spread it’s just frustrating for me haha.
Upgrades
I’ve considered newer Rams but they have a cad aam front diff which I don’t like. I really like the new f450 but no one makes a Cummins swap kit yet. Just can’t justify $100k + for a new truck. I’ve owned my truck since new so I’m trying to compete with trucks almost 25 years newer. It’s silly but I’m biased
