jigdog
Everything posted by jigdog
  1. ok so looks like i may need to replace orings and sealing washers can somebody tell me what size they are ?
  2. is this go from the back of the head down the driverside of eng to injpump ? my y2k has started hard starting too after sitting a couple days.
  3. How much oil have you had to add to the engine.
  4. got the truck maps sensor checked with scan tool with ez unplugged runs fine. sent ez to edge they got it at 1230p friday and fedex picked up the replacement at edge at 4pm on its way back to me. i requested a quick turn around now thats is service,much better than my rv dealer. thanks for all the help.
  5. How much per gallon of diesel are you using ?
  6. Can anybody give me a suggestion for a fuel additive better than stanadyne ?
  7. Key on ,then unplugged the ez and ran it and it didnt change it ,i was thunking the ez too but dont think so now. - - - Updated - - - when i checked the voltage of the map connection it was not plugged into the ez got 4.97 from the orange wire and .1 from the other two. but the truck did run any different with the ez unhooked.
  8. i followed the check the inst on checking the voltage for the map sensor correct voltage on the orange wire in the harness to map sensorcheck the black/light blue wire got .1 on the meter,the insturuction says to replace the wire. dont know if i can get that done.
  9. 1693 came up had it checked PO236 CAME UP.WHERE SHOULD I LOOK FOR A FIX
  10. the last two weeks i have been losing power that acts as if i am losing my chip power completely.i have great fuel pressure a new filter. I can throttle up slow and get no fueling smoke or power and then it will kick in and feels normal,boost seems to be normal ,close to 20,but no power. the only change i have made inoperation is adding some two cycle oil to the fuel for lube cause i had a injector that would stop working partly at idle. i have checked the chip connectors and they all seem tight. Could use some help figuring it out.
