transfer case crack
thanks will try
transfer case crack
thank u 291,000 miles prop shaft went bad just trying to buy some time just did trans and frontend tires ball joints tie rod end little thin on money now
transfer case crack
small hair line crack in transfer case 2004 3500 jb weld maybe help
Wastegate opens at 2500 RPM WOT
It was manufactured 4 of 2004. It's an electronic waste gate actuator. started within the last week. No gauges hooked up. Alright guys sorry for being an idiot. Don't know why I didn't take the two minutes to check it the other day but figured it out....
Hey guys, I have a 2004 3500 SLT single rear axle 5.9. Had an issue come up within the last week. Had my injectors and tubes and TPS sensor replaced about 6 months ago because of a starting issue. At wide open throttle 2500 RPM sounds like the wastegate dumps open and I lose all power but if you keep it floored you can see the RPMs climbing slowly. As soon as you let off the pedal and hit it softly you gain power again but right at 2500 RPMs it drops off again. Only code stored is a fan code p0483. Haven't had a chance to test the fan but it seems to be working.. I tried disconnecting the fan and driving it but it does the same thing at 2500 RPMs. Any help would be great. Thank you.
Who Has the Most Miles on a Dodge Ram Automatic Trans
still going
240,000 48re
2009 Dodge Cummins with bluetech
i have a 2009 got it new only thing i had was dpf clogged took it off with cat and straight piped it got 2 rest with a doogel once twice a week 65,00 out of warranty
- hard start
hard start
air leak without fuel leak at conector line to crossover tube
hard start
2004 3500 injector line to corossover tube can you have air leak without fuel leak make for a hard start
red fuel off road whats the diffrence
thats what I was saying dye only diff just 2 settle dispute with a buddy of mind not worth the risk of using thanks
samre fuel just dye
ok thanks 4 the info
is it just dyed or something esle
