jokra
Everything posted by jokra
  1. Just an update, I think the vacuum line from under the hood might actually go directly to the back of the switch, not the thing by the throttle. There are a number of vacuum lines directly in the back of the selector switch on the dash, and it makes sense that vacuum would go there first. But fortunately/unfortunately I didn't have to (yet) find out for sure, as I was able to patch the line under the hood. I grabbed onto that tiny little piece just barely sticking out of the firewall and pulled as hard as I could, and got it to slide out about 1/2". Just enough to slip some rubber hose over top. There wasn't enough room for a clamp of any kind or to wrap tape around it, so I squeezed a bunch of superglue on it, lol. Seems to be holding for now! If/when it breaks again, I'll probably have no choice but to run a new line all the way from under the hood through to wherever it needs to go. I'm definitely going to run it through on the drivers side though if I need to go that route, I have no idea why they went to the passenger side and behind the HVAC box, what a silly engineering idea.
  2. Thanks for the info @dripley! I was finally able to pull out my air cleaner and look closer, and I found the other end, but I can't get to it. I can see about 1/8" of it sticking out right next to the top evap line, where it goes through the firewall. Inside behind the glove box you cannot see this one, as it comes in directly behind the black plastic box and cannot see or feel it. So...rather than pull out the whole dash, do you know where this line ends up? Does it route over to the driver's side, down by the go pedal? I see some vacuum lines down there. If it really is one of those, I would much rather just route a new line all the way from there, through the firewall on the drivers side since there's already a hole, and then over to the broken piece by the air filter. But, before I pull apart the lines by the drivers feet I'd like to see if anyone can confirm whether or not that is really where that line ends up...? You'd think I could find that part of a diagram on the internet but I'm not having any luck.
  3. Hey guys, rather than start a new topic for something that has been discussed a bunch already, thought I would jump in on this one. I just finished installing new exhaust, and afterwards noticed that my air is only blowing out the defrost. As I've seen all over the internet, it seems like the most likely culprit is that I broke a vacuum line. I started tracing from the vacuum pump, and I'm having trouble figuring out exactly where the line runs from the main run across the cowl into the HVAC box. I see the line from the pump to the cowl line, and I see that it goes back toward the front, I assume for cruise control, and then there is another T that happens around the valve cover - for 4x4 probably? Then the line continues toward the passenger side, and it ends in the thing I'm holding in my hand in the picture. I assume this is supposed to be going through the firewall over there near the AC lines? As you can sort of see in the pic, it looks like the end of this may have melted. Or am I wrong, does everyone have one of these things hanging off their truck over on the passenger side? My 4x4 and cruise are still working just fine, and I'm guessing that is only because this one appears to have melted shut completely at the end. Do you agree? If I actually cut off the end of this hose, then I would probably lose 4x4 and cruise as well? My question really is - where do I need to hook this thing to? I'm afraid since I don't see anything obvious that it might have fallen back into the cab through the firewall, and I don't look forward to trying to find it from inside. Does the vacuum line from the engine bay run into the HVAC box through a port somewhere near the heater core lines?
  4. Sure thing! Here are sections 393.65 and 393.67. https://www.gpo.gov/fdsys/pkg/CFR-2011-title49-vol5/pdf/CFR-2011-title49-vol5-sec393-67.pdf
  5. Sorry, this is a duplicate post from where I put it originally, but it applies to this conversation as well so wanted to get all of your opinions on it too... I read over the DOT information, and came away with the conclusion that sumps are perfectly legal. Here are the details on what I found. Please correct me if I read any of this wrong, as I do really want to understand this, but I couldn’t find anything in here that tells me a sump on the bottom of a diesel tank is illegal on these trucks: https://www.gpo.gov/fdsys/pkg/CFR-2011-title49-vol5/pdf/CFR-2011-title49-vol5-sec393-67.pdf Regarding 393.65: The “gravity or syphon feed prohibited” absolutely does NOT apply to our trucks. This is clearly taken out of context by that one website and only relates to feeding directly into the carb or injector. (d) Gravity or syphon feed prohibited. A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector. Furthermore, down a little ways in the fuel lines section it even references a sump and the fact that any fuel lines which are more than 2” below the tank or the sump need to be protected: (f) Fuel lines. A fuel line which is not completely enclosed in a protective housing must not extend more than 2 inches below the fuel tank or its sump. Diesel fuel crossover, return, and withdrawal lines which extend below the bottom of the tank or sump must be protected against damage from impact. Regarding 393.67: And then regarding anything found in 393.67 – this does not apply to most personal trucks, unless you are using it commercially. It states at the beginning of 393.67 that these rules are for commercial motor vehicles, as opposed to 393.65 which states just “motor vehicles”: (a) Application of the rules in this section. The rules in this section apply to tanks containing or supplying fuel for the operation of commercial motor vehicles or for the operation of auxiliary equipment installed on, or used in connection with commercial motor vehicles. Even if we did have to conform to 393.67, rule #4 under construction of tanks shows that a drain or bottom fitting must not extend more than ¾” lower than the tank or sump. There again it references a sump as a valid option. (4) Drains and bottom fittings. (i) Drains or other bottom fittings must not extend more than three-fourths of an inch below the lowest part of the fuel tank or sump. And then #5 shows us that diesel tanks are exempt from the requirement that fittings be located above the normal fuel level, so that one doesn’t apply to us either. (5) Fuel withdrawal fittings. Except for diesel fuel tanks, the fittings through which fuel is withdrawn from a fuel tank must be located above the normal level of fuel in the tank when the tank is full.
  6. I read over the DOT information, and came away with the conclusion that sumps are perfectly legal. Here are the details on what I found. Please correct me if I read any of this wrong, as I do really want to understand this, but I couldn’t find anything in here that tells me a sump on the bottom of a diesel tank is illegal on these trucks: https://www.gpo.gov/fdsys/pkg/CFR-2011-title49-vol5/pdf/CFR-2011-title49-vol5-sec393-67.pdf Regarding 393.65: The “gravity or syphon feed prohibited” absolutely does NOT apply to our trucks. This is clearly taken out of context by that one website and only relates to feeding directly into the carb or injector. (d) Gravity or syphon feed prohibited. A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector. Furthermore, down a little ways in the fuel lines section it even references a sump and the fact that any fuel lines which are more than 2” below the tank or the sump need to be protected: (f) Fuel lines. A fuel line which is not completely enclosed in a protective housing must not extend more than 2 inches below the fuel tank or its sump. Diesel fuel crossover, return, and withdrawal lines which extend below the bottom of the tank or sump must be protected against damage from impact. Regarding 393.67: And then regarding anything found in 393.67 – this does not apply to most personal trucks, unless you are using it commercially. It states at the beginning of 393.67 that these rules are for commercial motor vehicles, as opposed to 393.65 which states just “motor vehicles”: (a) Application of the rules in this section. The rules in this section apply to tanks containing or supplying fuel for the operation of commercial motor vehicles or for the operation of auxiliary equipment installed on, or used in connection with commercial motor vehicles. Even if we did have to conform to 393.67, rule #4 under construction of tanks shows that a drain or bottom fitting must not extend more than ¾” lower than the tank or sump. There again it references a sump as a valid option. (4) Drains and bottom fittings. (i) Drains or other bottom fittings must not extend more than three-fourths of an inch below the lowest part of the fuel tank or sump. And then #5 shows us that diesel tanks are exempt from the requirement that fittings be located above the normal fuel level, so that one doesn’t apply to us either. (5) Fuel withdrawal fittings. Except for diesel fuel tanks, the fittings through which fuel is withdrawn from a fuel tank must be located above the normal level of fuel in the tank when the tank is full.
  7. Guys, thanks again for all the advice on this topic. I finally decided on a solution and finished installing it this week. I ended up going with a GDP Fuel Boss mechanical pump that is fed from a Beans Diesel Sump. Going the route of the sump solved the following issues I was concerned about: It allowed me to continue using my in-tank pump as a backup. Since I didn’t have to modify the basket at all, my in-tank pump is still sitting there happily running whenever I need it to. I never had to drop the tank or even touch the top of it! It was nice not to have to worry about dropping the tank for a draw-straw install, and I never even had to touch the top to try and unplug the wiring harness or anything. For the Fuel Boss install you do have to cut one of the lead wires that supplies power to the in-tank electric pump, but I tracked it down under the hood and cut into it there instead. No potential quarter tank issues since there is no draw straw. I know some people have gotten their straws installed well enough that this isn’t a problem, but there are many more stories on forums about people that do have ¼ tank issues after installing draw straws, so it is nice not to have to worry about that. I got both positive and negative feedback on doing a sump, but I’m glad I did it for the reasons above. It works great so far. I installed a shut-off valve on the sump so if anything ever did happen to the hose or if I need to shut it off for whatever reason I can just turn the valve. It also has a drain plug so if I ever do need to empty the tank and remove it for whatever reason, that will be easy too. I wanted to update this thread because I never found a lot of information about whether or not a Fuel Boss could co-exist with the in-tank pump, but it definitely can. Here's a little story to prove that the electric still works as a backup: It’s common for “tank gunk” to have to flush its way out of the system following installation, since you kick up debris and stuff when you empty the tank. Shortly after I installed the Fuel Boss I got on the throttle pretty hard and my pressure went up close to 20, and when I let off the pedal something must have gotten stuck in the bypass valve and held the piston open because my pressure suddenly dropped down to 5. It stayed between 5-8psi the rest of the way home. I figured something must be stuck in the bypass, holding it open, but before I took apart the bypass valve and cleaned it out, I experimented a little. If I unplugged my electric pump my pressure would read zero when running. The bypass was allowing so much "overflow" fuel past it with the piston stuck open that my gauge was registering zero, yet when I was driving home I never saw zero, it held itself at 5 or above. I say this to prove that the Hobbs switch which tells the electric pump to engage when pressure drops is an immediate reaction. As soon as my pressure dropped the electric pump kicked in and I never even noticed in the truck, except that I was watching my fuel pressure gauge like a hawk because I was only a few miles into it after having installed everything. By the way, I took the bypass valve apart (super easy), put it back together, and I’ve never seen that symptom again. It takes about 30 seconds to pop the bypass off, so even if this happened on the road it would be very easy to fix it with two crescent wrenches. Hopefully this post isn't too long. I created a video with some detail on how I ran everything and how I did the wiring, if anyone is ever interested in doing one of these installs. Otherwise there are pictures and descriptions down below. Sump on bottom of tank goes with 3/8” lines straight up to the Fuel Boss that is mounted via the front three oil pan bolts. The only thing in-line on the way to the pump is a fuel strainer that comes with the Fuel Boss install kit. I mounted this on the driver’s side of the transmission for easy access to change it out in the future. Then from the Fuel Boss you head back to a “T” that is directly underneath the fuel filter canister. From the T you go both to the back of the truck, as well as upward toward the filter. On the line that goes to the back, you install the bypass valve. This is what opens at roughly 18psi and allows excess fuel to return to the tank. I hung the bypass valve right by that fuel strainer, so they are both super easy to access. Then from the bypass valve you just run to the back and return to the tank. I cut the filler neck hose and inserted the return manifold there. Again, for this I did not have to drop the tank or even have to remove the filler hose – I just cut 1” out of it right where it was. Moving back toward the front, the top of the “T” as you can see in one of the above pictures heads directly north toward the fuel filter. In this section of line you install the Hobbs switch which tells the electric pump when to turn on or off. Two wires go from the Hobbs switch to one of the lead wires for the electric pump. I cut into those wires right behind my master cylinder. If your stock lift pump is still on the block you’ll have to tap into them in another place, but mine was so easy to get to: Before you hook your new line to the back of the fuel filter canister, figure out how you are going to plumb in your factory supply line from the electric pump. I ran a new piece of hose from the metal hard line under the driver’s seat up directly to the filter. You have to install a check valve in this line (comes with the Fuel Boss kit) so that the Fuel Boss doesn’t back-feed down this stock supply line. In some cases you can probably re-use the factory dorman connector and tap back into the dummy “fuel block” that Dodge put in place of where the on-block pump used to be, but mine looked gross and rusty so I bypassed that whole mess and went directly to the fuel filter with both my Fuel Boss supply line as well as my factory supply line. I used a banjo to 3/8” quick connect fitting for the factory line, and then a JIC 90 for the Fuel Boss supply line. And that’s it! While I had the whole fuel system apart I also installed a big line kit between the filter and the VP with a needle valve and snubber for my gauge in that run. I hope this helps someone else be able to make the decision on which direction to go. Installing a FASS or AirDog would have been much simpler, but I'm glad I took the extra time up front so that I now have dual pumps in the event that something goes wrong while I'm on the road. Jordan
  8. I can almost hear Jeff Foxworthy in the background: "If, for any reason, you find yourself with three open beers at the same time.......you might be a redneck" ;) lol
  9. Just an update for those interested in what Richard@GDP had to say about using a Fuel Boss alongside the in-tank pump on my 2001. First of all, you all were right - what a great guy. Easy to talk to, picked up the phone right away, and is a straight shooter. In fact, he told me I really don't need to change anything on the truck at the moment...more on that later. I can definitely run a Fuel Boss alongside my in-tank pump in order to have it for priming and as an on-the-fly backup in case the Fuel Boss belt breaks or something like that. What I need to do if I go this route is make the order over the phone, as he will get me the 2005-2007 install kit, but with the 2001 pump mounting bracket. The 05-07 kit includes its own draw-straw style pickup tube that the Fuel Boss will pull from. Then after leaving the pump, you T to the factory filter and to the return. The existing in-tank pump continues to be plumbed directly to the factory filter as well, with a check valve in place so that it only runs and pumps fuel if/when the Fuel Boss is not keeping up to pressure. This way the in-tank will run during starting and for priming, and if the Fuel Boss stops working. Otherwise, the Hobbs switch turns off the in-tank as soon as pressure is up. He said at least half of their customers use no electric lift pump whatsoever. As long as you don't lose prime, you never need to use the electric during starting. When it comes time to prime, you can either remove the inlet line from the VP and crank the engine to pull fuel through, or some people just pop the belt off the Fuel Boss and spin it with a drill or something similar, and manually prime it that way. Rich then asked me what my current numbers were on my in-tank. When I told him 8 idle and that I can drop it below 5 when I step on the gas he said "That's normal, probably been those same numbers since it was installed. If you're not modifying the truck at all, I'd just drive and enjoy it." The majority of the failed VPs that he has seen have boiled down to a build issue with the board, not having anything to do with fuel pressure. On mine particularly, since the VP44 was replaced in 2008 with a new one from Chrysler, I should have one of the newer "good" ones that do not have this design flaw, and it'll probably run forever just like it is. While that makes me feel better about puttsing around with it here and there unloaded, I still plan to upgrade the lift pump before I tow anything serious with it. ;)
  10. Haha, nice. At this point I will just be thrilled to see more than 10psi on my fuel pressure gauge, whichever solution I end up with. Good to see someone else here from the mitten. I'm straight west of you a few hours, close to Holland. Are those Silver Lake flags in your profile pic...?
  11. @jlbayes Where in Michigan are you located? Maybe you can stop by and p-pump mine too. Should only take a couple hours, right? lol
  12. Keep in mind too that voltage at the battery only drops about 1.5v from a fully charged to fully dead battery. You should only see this amount of fluctuation on a good battery. I don't remember the exact cut off number, but if you ever see voltages lower than 11 - there's a good chance your battery is toast. Sorry, "fully dead" is probably the wrong way to describe it, but if a battery measures lower than that threshold it will be dead enough to appear to be dead to a vehicle anyway.
  13. That is a great point. I do not typically see dirt roads, but do have a quarter mile of gravel driveway and it is amazing the amount of large stones my new tires pick up. Every time I leave the driveway I hear them pinging off the side steps constantly until I hit about 30mph. So many choices. I do plan to at least call GDP and ask what kind of experience he has with people running a Fuel Boss alongside the in-tank pump. I imagine the plumbing would be more complicated than with a block-mounted pump, but it's what I've got to work with.
  14. @Mopar1973Man Thanks! That is the info that I had surmised after reading through all the posts, but it's nice to see the numbers laid out to know exactly where I stand. My PSI numbers have likely been the same numbers for the past 75k, which is when it got the in-tank pump and a new VP44. So I'm partly scared that replacing the lift pump at this point will cause the VP to choke again, but I know that if I leave it and drive it, I'll end up toasting both for sure, so I'd like to make it right asap. As for the color - I'll admit that in certain light it looks purplish. But as I told dripley earlier I checked the window sticker and it says "Beast Mode Red", and ain't nobody gonna tell me otherwise ;)
  15. I just got the "Battery Tender Junior", and I love it so far. Didn't get it for the Cummins, as I can let that one sit for weeks without starting and it still never takes more than 2 cranks to fire up. So to that point - yes you should definitely figure out where your juice is going, because these trucks don't suck the batteries dry as normal behavior. I rotate the tender between batteries in the cars that sit in the barn over winter, and it works great. I should really get more of these so I don't have to rotate it, but I switch it from one to the next about once a week or every other week, and it seems to work great so far. Spring will tell for sure, as I usually have to replace the battery in the Chevelle almost every year after I neglect to take care of it over winter.
  16. My pressure goes from "bad" at idle to "terrible" when I press the go-pedal. So I've been accelerating very slowly and only driving it when necessary until I get the parts. Fortunately I work from home most of the time and don't HAVE to drive it very often. About 9psi idle, normally about 7psi when accelerating slowly and cruising, but if I accelerate hard I can make it dip below 5 if I want to. Now, as a sidenote, I was talking to a neighbor recently who has been a diesel mechanic (school buses) for almost his whole life. He said they have had many motors over the years with various Bosch injection pumps, and he said as long as you have 2psi moving to it, he has never seen any regular problems because of lack of fuel pressure. I know that directly conflicts with what everyone says about these VP44s, but that was his experience. He wasn't working with the Dodge interpretation of the setup, obviously, so maybe that makes all the difference. I also have another neighbor with a 99 3500 CTD that just rolled over 300k. I asked him a couple weeks ago what he did for his lift pump and he said "what lift pump?" So clearly there are some cases of not doing a lick of different from the factory setup, and it lasting a really long time. But...I don't want to risk it. ;)
  17. @CUMMINSDIESELPWR Thanks for the input! I'm hearing more and more good about the Fuel Boss. If I had an on-block factory pump that still worked, I think I'd be sold by now. Is that the way yours is setup? Or do you run just the Fuel Boss with no other pump for starting and priming? I'm curious if anyone has the Fuel Boss with the in-tank pump from Chrysler. Would be interesting to find out whether or not those two can co-exist. I have some ideas about how I might be able to make that work, but not sure how it plays out in real life.
  18. Most years we are about waist high in lake effect snow at this point, this winter has been pretty lame. We keep having these crazy 40 degree days where everything melts down a bunch before it gets cold and snowy again. Finally had to find the 4x4 lever yesterday, only had to pull two people out so far.
  19. @dripley Thanks for the kind words! I love it, just hope it loves me back for a long time to come. ;) I am pretty used to taking flack for the short box already. Anytime a family member needs something hauled I hear things like "we may need to rent a bigger one, I'm not sure it'll fit in Jordan's little bed" or my dad's favorite "let me know when you get a real truck" (his 1500 is an 8' box which apparently wins the day) As for the color, I have the window sticker still in the glove box. I'd have to walk out there to double check, but I'm pretty sure the color code is "Beast Mode Red" -- not "purple". But alas, I've been ribbed about this numerous times as well...usually by Chevy drivers, to which my only response is to pull them out of the ditch or tow them home.
  20. @01cummins4ever Sometimes I wish I had the long box for hauling stuff, but I just love the look of the short box. It's the right ratio of truck to box for my eyes. The 2nd gen 2500 extended cab short box is my ultimate favorite truck of all time. If I could pick any new truck ever made, I think it would be one of these, brand new. By the way, your response is exactly the reason I love these forums. I was like "I don't remember saying anything about it being an automatic" - then I noticed the little yellow dipstick in the one picture the level of detail you guys catch and the knowledge you have is awesome. If we're wishing for things, I may choose the 6 speed though. Had to rebuild the auto right after I got it. But even with a band cracked 3/4 of the way through, she still pulled herself 45 miles to the shop. It's got a shift kit and bigger converter this time around. If only Cummins made the motor AND the tranny... @JAG1 Good point on not having the separator with the Fuel Boss, that is a plus of the electrics (though it's also a negative that you have ongoing maintenance costs for filters I suppose). I have not read anything technical yet on using 2 cycle oil, but I have seen quite a few people post about using it. I have also heard some of these trucks that run way quieter than others, and always wondered why. I get the overall impression that adding 2 stroke to every tank is a good thing? Somewhere around 1 ounce per gallon of fuel? Does it matter what kind of oil? I would definitely like to try that as long as I've got the details right. I don't mind putting a little extra money in her if it means she'll last longer. I would love to see 300-400k numbers some day (or double that!) but my current work arrangements only have me driving it about 5k per year, so chances are Michigan salt will eat the rest of the truck away long before the Cummins dies. Is it not legal to draw fuel from the bottom anywhere in the US? Or is that an inspection thing that is state specific? We don't have any inspections here thank goodness. Most of the Cummins you see around here have 48" stacks and you just have to guess at what the truck actually looks like because you can't see it through the black smoke ;) I'm exaggerating a little of course, but not much...
  21. Good afternoon! I'm brand new to the forums here, and brand new to the diesel world. This site looks like the best community of 2nd gen Cummins addicts I could find anywhere, so I am honored to join and learn from you, and hopefully one day contribute to helping others as well. Hopefully this is an appropriate place for an introduction, I really enjoy reading the intros from some of you and learning about how your trucks are setup, and their history, so here's a shortened version of mine: I bought this 2001.5 from a family member who bought it brand new. He purposefully waited until the 2001.5 version to get the disc brakes in back. It has always been meticulously maintained, and was completely stock when I got it. Well, other than driving better than when it was new. Quite a bit of time was put into getting the steering right, I don't know what exactly it has up front that is different than stock, but I can see one of the steering "kits" up there. Whatever it is works, because it drives straighter and with much less steering play than my dad's 99 half ton Ram. This one is also a little unique in that it has the plow-prep package, which I was told includes stiffer springs in front, and the camper package so it has an extra leaf spring in back. So it sits quite a bit taller than others I've been next to, and rides like an oak tree. Actually, it rides much better with an oak tree sitting in the back. I haven't done much to it. A buddy owed me a favor and installed a 2" coil spacer to level out the front, at the same time we put in Bilstein 5100s. Just the front for now, I have a set for the rear on order but haven't gotten them yet. I also removed the turbo silencer ring because I was new to diesel and excited to whistle, and of course youtube told me that would make it whistle! As you all know, removing that ring does absolutely nothing to how loud you hear the turbo, at least to my ear, so I also installed a BHAF (not just for the whistle). I can't remember for sure as this was last summer, but I am pretty sure the motivation for the BHAF came from Mopar1973Man himself, before I knew how famous you were in this sector. I then showed my dad what I had done and mentioned something about "wonder if I should put a heat shield on that" - and the next thing I knew he had made me one, out of diamond plate. You can see that in one of the pics. Otherwise it's all stock. Always had FleetGuard filters, oil always changed every 5k, it's never even seen the inside of a car wash, always washed by hand. I'll try my best to maintain it as well as he did, but it's winter now and my garage isn't heated, so that last one may have to change. She likes to haul firewood. Oh, and you can see the Cummins sticker on the back, which of course adds 80hp at the wheels, what I've been told. ;) And the fact that it's stock is the reason I ended up on your site and why I wanted to post this message in the first place. Fuel delivery. The good, the bad, and the ugly. The history on my truck is that around 80k the lift pump was replaced with the in-tank by a dealer. They did this just because he had read that they were a common problem and wanted to make it "right" (what they considered to be right at the same, this was in 2008 or so). 100 miles after replacing the lift pump with the in-tank, the VP44 died. I assume the old lift pump was actually bad and the replacement put the VP over the edge. So it got a brand new VP44 from the dealer as well. I just rolled over 154k with it, and the more I read the more I worry. So I got gauges. And found I only have about 8psi idle, and if I stomp on it I can dip it below 5. I didn't want to create a new forum post to cover information that already exists in so many posts already, and so I searched your forums for anything fuel related, and I read ALL of them. And I thought I had decided on what I was going to do - FASS 150 titanium with a Draw Straw V, until I saw someone mention a Fuel Boss. Then I saw someone else say Fuel Boss, then it seemed like every post I read had at least one comment in it about the Fuel Boss! Lol. So I'm hoping to get a little further insight there. FASS vs Fuel Boss - ideas? Good, bad, indifferent? One consideration is that it sounds like some are using the Fuel Boss with no electric pump whatsoever. Over the long haul, will that be hard on the VP44 to be pulling its own fuel during startup? What if I do something like install a Fuel Boss hooked to a Beans sump...? That way I could leave my in-tank stock pump in place, since it still works? But if I do that, I'm confused as to how I would plumb it properly, since I cannot plumb the T from the Fuel Boss into the in-tank pump, they would be pulling from separate fuel sources. Would that even work? I am not opposed to going FASS+DrawStraw, though I'm not super excited about dropping the tank just because I've never done it before. But if I can make Fuel Boss+Beans Sump workable, it's possible I could get all this working without even having to touch the top of the fuel tank...? Let me know if you see holes in my theory, because I'm sure I'm missing something important that will leave me stuck. Thank you so much, and it's great to be part of this group!
