Tractorman
  1. I tend to agree with that conclusion, but I wouldn't rule out a ground issue. Poor grounds can cause irrational behavior and can mess with your mind. Have you tested the CCD circuit (as described below) while you are making changes in the blower motor circuit? It would be interesting to see if CCD voltage readings reflected a change when the "no buss" message showed. John
  2. It is only the blower motor relay coil (#85 and #86) that draws from this fuse. That current draw is less than 200 milli-amps. The switch portion of the relay (#30 to #87) carries the full load for the blower motor - #12 40 amp fuse in the PDC. Most likely you have a short circuit to ground downstream of the mirror heater switch / relay that is causing the blown fuse when you activate the mirror heater switch. At least you now know where to begin looking for this problem. Back to the "no buss" message issue - I will have to think about that some more. John
  3. Since you mentioned this, I did find a correlation between the heated mirror switch and the blower motor circuit. The 10 amp fuse #2 in the junction block feeds Joint Connector #8 which connects to the mirror heater switch and some other components INCLUDING connection to the coil of the blower motor relay. Was it the #2 fuse in the junction block that blew? John
  4. From the FSM, the blower motor and HVAC controls ground at G200 which looks like a stud behind the kick panel. Hopefully, this illustration can help (unless, of course, you have already seen it). John
  5. This is probably clear in your mind, but it is confusing to me. I am not quite sure of what you are saying. Can you write it differently? Example: Saying "no buss" message can mean something different than saying no buss message. Maybe you can say, "I am getting the P1689 code "no buss" message"; or "I am no longer getting the P1689 code, "no buss" message." Thanks, Edit: I reread your posts and I think I know what you are saying. John
  6. Sounds like you are on the right track! Keep us posted. John
  7. Thank you for the details of your repair history along with the timeline. This helps. If I am understanding correctly, the engine runs fine now except for the brief low idle or the stalling. Have you driven the truck? How does it drive, other than the brief low idle or the stalling? I am beginning to think that it is injector related. John
  8. Exact details are important here. In your mind you know exactly when you did everything - we don't, you have to tell us. Please answer each question. Why did you replace the VP44 - what was wrong with it? What were the symptoms? Did you replace injectors, tubes, and lines before or after the VP44 replacement? Did you use the key that came with the re-manufactured VP44 ? Have you inspected the electrical connector to the PSG for pins that could be pushed back? It is hard to know with the video what you are doing with the throttle. I think it is clear that the engine idles as it should. When you step on the throttle in the first video, did you make the rpms go past 3,000 rpm, or did that happens on its own? Please, don't skip any questions. Thank you, John
  9. @jeremyf9806 , you have an unusual problem. Can you give some history on the parts that you replaced. Which parts were replaced before the problem and after the problem. What was the reason that caused you to replace the VP44 injection pump? Since the engine starts quickly and idles smoothly, leaks or injectors are not likely to be your problem. The leaks need to be repaired and they could make the engine hard to start after it sets awhile, but they are not making the engine behave as you describe. The programmer is a possibility. I would completely remove the programmer electrically. I would double check the electrical connection to the PSG on the VP44. Make sure that a pin has not been pushed back inside of the connector. Regarding the new re-manufactured VP44 injection pump that you installed - is the PSG new or re-manufactured? was the re-manufactured pump tested on the Bosch 815 test stand by the rebuilder? Assuming that the engine was operating normally before you replaced the VP44, I wouldn't worry about checking the valve lash. John
  10. I can't answer that particular question. Personally, I would be looking for three things with a re-manufactured VP44 injection pump. a new PSG latest updates through an authorized Bosch rebuilder the VP44 injection pump to be rigorously tested by an authorized Bosch rebuilder, using the Bosch 815 test stand If the pump supplier cannot confirm these three things, then I would move on to another supplier. When it comes time to replace my replaced VP44, I will be following my own advice. By the way, my replacement VP44 has now logged over 310,000 miles. John
  11. Yes, it is likely. I would verify that you have good lift pump flow, though. The P2016 code is usually a timing related code and will de-rate the engine power until it corrects itself. The advanced timing that you heard at the fueling station triggered the engine de-rate and set the code. I would not purchase the VP44 that you are asking about at Diesel Auto Power. That pump comes with a re-manufactured PSG and it is not calibrated to the pump using the Bosch 815 test stand (about a 4 hour test, I think). I believe DAP does sell a more expensive model with a new PSG that is calibrated to the pump. Maybe @Mopar1973Man can verify. You are probably okay to continue to drive the truck if you need to - you can probably change your driving techniques for the interim which will help avoid the engine de-rate. I had the same symptoms on my truck about 20 years ago. I learned how to drive the truck to avoid the engine de-rate. I drove it for another year (20,000 miles) before I had the VP44 pump replaced under warranty at the time. John
  12. Most of the the HVAC circuit consists of switches in the ground side and there is a blower motor relay and an AC clutch relay as well as a refrigerant low pressure switch. There is a 12 volt supply to the blower motor and the AC clutch relay. I would be more inclined to trace wires in the CCD bus circuit as those pair of wires can only be connected to components operated within CCD system - nothing else. Not that Joint Connector #7 is a hub for connecting to many of the CCD components in the system. John
  13. Maybe the previous owner has messed up the wiring somehow. It may be worth physically tracing the CCD bus circuit to see if any wiring has been damaged or tapped into. John
  14. Running the 10 gauge wire from the dash to the negative battery terminal was a good test, but your test results indicate that the body ground is NOT the problem. As far as I know, there are only two ground connections for the HVAC control panel and the blower motor - ground # 200 and # 201 - both are connected to the dash, just separate locations. Not sure where to got next. John
  15. You didn't answer any of the questions regarding how you did your voltage drop test. A voltage drop test will give you conclusive information regarding whether or not the circuit you are testing is good or bad. It is one of the best electrical tests that one can do, but is also one of the least understood. Reconnect the blower motor ground in the center dash. Connect your multi-meter to that ground and the battery post ground. Set the meter to DC volts on the 00.00 scale. Start the engine and turn the blower fan to high. Read and record the voltage drop. Any voltage above .1 volts during this test is considered to be excessive - the higher the number, the worse the condition . If this is the case, this means that the dash / body is not at full ground potential. This will affect the operation of any electrical devices that use the body as a ground. I like doing voltage drop tests when I find it difficult to solve an electrical problem. Voltage drop tests don't lie, but you do have to be meticulous when you perform them. The best part of using this test is that you do not have to disturb any electrical connections in order to perform the test. Done properly, voltage drop tests save time and provide accurate conclusions. Maybe you already know all of this, but I can't make that assumption. I believe there are two body-to-battery grounds for the driver side battery. One is located on the body between the driver side battery negative post in the headlight area and I think the other is under the battery tray. John
  16. Are you doing your voltage drops correctly? Is the engine running with lots of electrical devices turned on to full power? If you are doing this test without the engine running and no electrical devices are operating, then the results of this test are meaningless. A voltage drop in a normally operating electrical circuit will always register more that 0.00 volts. Typically, you would see up to .1 volt drop while a good circuit is operating. Since you are having the strange issue of setting a P1689 with no buss on the CCD when you turn your HVAC blower on, this would be a good place to perform a voltage drop test. Start the engine and turn the blower fan to "high" speed. You will want to measure the voltage drop from ground connection # 201 (Instrument Panel Right Center Support) to the negative post of a battery. The blower must be operating on high speed. A .1 volt (or less) drop would be considered normal - a 1.5 volt drop would be a problem. If your meter reads 0.00 volts, then you have a poor connection with your meter. John
  17. I suspect that you may have a poor body to frame ground, or poor body to battery ground. Since the blower motor switch grounding and the data link grounding are in the body ground circuit, a poor body to frame or body / frame to battery ground connection could influence the CCD circuit. Body ground # 200 (located on the driver side inside the cabin) and engine ground # 107 are part of the CCD circuit. You could temporarily run a jumper cable from the body directly to the battery ground post and then operate the HVAC blower fan to see if the symptoms go away. John
  18. I think you could temporarialy wire in a LED lamp to the OR/BK wire from Connector #2, terminal #11 of the PCM. Wire the other side of the LED to ground. The lamp would be on all of the time after the engine is started, but it would go out when the torque converter is commanded to lock up. I don't think it would cause you any side effects and it would do what you want. John
  19. No, they shouldn't be tight. I think you are worrying about a potential problem that does not exist. Your explanation of your concern was well written, and I think accurate. The two valves that you referenced were closed, but the #5 and #2 pistons were 120° on their approach to TDC. The cam lobes were still ramping down or up (depending which valve is being referenced) so the clearance was not the set clearance (because of the ramp). BUT, the clearance would be a normal clearance. John
  20. I didn't say that quite right. The intake valve would be fully closed, but would not have reached the full .010 clearance yet. John
  21. I think everything is normal. Since you were at TDC on the compression stroke #6 cylinder, that means the cylinder #5 (next in the firing order) would 120 degrees away from arriving at TDC compression stroke. That intake valve would not be full closed until after BDC, which could explain the .003 inches. This hurts my brain. I think #2 cylinder is behaving the same way - just in the exhaust stroke. John
  22. Dave, this is what I used. There are lots of choices - just make sure that the free flow direction requires very little pressure differential to flow. John
  23. There are a couple of things you can do for better reliability for the VP44. First, get over the idea that 14 psi lift pump pressure is needed to ensure there is always return fuel flowing to the fuel tank from the VP44 (if you still believe this). The lift pump pressure has no influence whatsoever on the quantity of return fuel from the VP44. The VP44 return fuel flow is controlled only by the VP44's internal vane pump and its regulating valve (over 100 psi) and the 14 psi overflow valve. Being that the internal vane pump is of fixed displacement design, the pump's output flow is always the same at a given engine rpm - regardless of engine load or lift pump pressure. When I performed VP44 fuel return flow testing, I installed a lift pump bypass circuit with a one-way check valve to demonstrate that turning off the lift pump did not change the return flow volume from the VP44. I did a 30 mile road test without the lift pump operating and the engine performed flawlessly under all operating conditions. So, when I reconnected things after my testing, I thought why should I remove the lift pump bypass circuit with the one-way check valve? If the lift pump stops working, the bypass circuit would go into action and continue to feed the VP44 pump - a win, win situation. If a lift pump should fail on a road trip, my low fuel pressure indicator lamp would light to make me aware of a problem, but I could continue driving to a place to do the repair without harming the VP44. For lift pump pressure sensor reliability (fuel gauge or warning light system) install a snubber and 24 inches of grease hose with 1/8" NPT fittings on each end. This arrangement will greatly increase the life sensors. I used a pressure switch for a warning LED light on the dash. John
  24. Glad to hear the truck is up and running well. Looks like your first VP44 lasted about 100,000 miles longer than the second one. My first VP44 failed at 87,000 miles and the second one is still going at 397,000 miles on the odometer, so 310,000 miles on the second Vp44. I won't be surprised to see a failure in the near future, but that's okay - it has been reliable and has had a long life. John
