01dodge24v5.9
Everything posted by 01dodge24v5.9
  1. The dark red line is what I'm wondering about see how it falls at line 21. And the engine load dips kinda wired also from line 22, 23. All at WOT.
  2. Here is my first pull at WOT. For some reason their is a bad dive in the CAN Bus fueling to 2350 at 2887 rpm ? Currently running the edge tune on level 3 no wire tap, the red are the things I'm going to change. I get a little haze at cold idle and really no smoke at WOT. Tell me what you think? Edge Number of Power Levels 7 RPM Limit 3200 Valet Mode Maximum Valet Mode Power 25 Pump Tap Parameters List Maximum Fuel Stretch 2200 TPS Pump Maximum 100 TPS Pump Minimum 10 0 Min Pump Tap Fueling % 0 Pump Tap Min PSI 0 10 Boost Scaling 30 40 Timing Parameters Fuel Load Timing 0 2 Low PSI Timing Reduct 4 5 Timing Reduct Scaling 100 50 LightThrottle Timing Adv 4 3 Light Throttle Limit 25 30 Timing Equilzer 1500RPM 15 16 2000RPM 18 19 2500RPM 21 24 3000RPM 24 30 MAX 25 Boost Level Fueling - CAN Bus 0 PSI 80 1 PSI 82.2 2 PSI 84.4 3 PSI 86.6 4 PSI 88.8 5 PSI 91 6 PSI 93.2 7 PSI 95.4 8 PSI 97.6 9 PSI 99.8 10 PSI 102 11 PSI 104.2 12 PSI 106.4 13 PSI 108.6 14 PSI 110.8 15 PSI 113 16 PSI 115.2 18 PSI 119.6 20 PSI 124 22 PSI 128.4 24 PSI 132.8 26 PSI 137.2 28 PSI 141.6 30+ PSI 146 Here's the numbers look at the CAN Bus between 2828 and 2849 RPM ? Boost EGT Load Fuel psi RPM Throttle Slip CAN B Timming 1 473 20 20 745 0 5 781 13.71 1 473 21 20 760 0 5 1160 13.73 1 473 21 20 961 12 19 1346 14.48 1 473 26 17 1169 12 19 1318 16.08 1 490 26 17 1465 20 16 1248 14.65 1 490 30 14 1532 20 16 1252 14.3 1 532 30 14 1550 21 28 1172 14.81 1 532 29 16 1563 21 28 1148 14.87 1 569 29 16 1577 21 30 1166 14.96 1 569 29 18 1583 21 30 1211 14.6 2 600 29 18 1614 22 23 1222 15.58 2 600 29 21 1625 22 23 1191 15.64 2 631 29 21 1652 24 18 1265 15.79 2 631 33 18 1733 24 18 1434 15.69 3 666 33 18 1853 41 22 1634 16.21 3 666 45 16 1989 41 22 2208 17.83 4 727 45 16 2194 70 36 2473 17.89 4 727 62 14 2320 70 36 2627 18.64 5 825 62 14 2564 70 39 3078 20.89 5 825 83 13 2853 70 39 2762 22.99 14 934 83 13 2887 100 42 2350 23.2 14 934 75 12 2849 100 42 3479 22.99 20 980 75 12 2928 100 16 4092 23.44 20 980 100 12 2952 100 16 4095 23.59 36 1028 100 12 2976 100 6 4095 23.74 36 1028 100 12 2975 100 6 4095 23.74 36 1050 100 12 3046 100 9 4095 23.98 36 1050 100 15 3028 100 9 4095 23.94 36 1066 100 15 3047 100 13 4095 23.98 36 1066 100 16 3059 100 13 4095 24.01 36 1072 100 16 3088 100 12 4095 24.06 36 1072 100 16 3105 100 12 4095 24.1 36 1077 100 16 3088 100 11 4095 24.06 36 1077 100 18 3125 100 11 4095 24.14 35 1076 100 18 3079 100 18 4095 24.05 35 1076 100 18 3116 100 18 4095 24.12 36 1074 100 18 3022 100 9 4095 23.93 36 1074 100 19 2988 100 9 4095 23.8 37 1083 100 19 2994 100 2 4095 23.86 37 1083 100 19 2999 100 2 4095 23.89 38 1094 100 19 3000 100 0 4095 23.89 38 1094 100 19 3029 100 0 4095 23.95 36 1103 100 19 3041 97 6 4095 23.97 36 1103 100 22 3023 97 6 1997 23.93 20 1086 100 22 1973 0 8 0 19.26 20 1086 0 18 1935 0 8 1 19.12 10 1000 0 18 1762 0 17 0 19.33 10 1000 2 18 1611 0 17 426 20.07
  3. Okay flashed it with the new V2.7beta, I'm assuming I need to run the version 2.7 quadzilla test, under vehicle selection?
  4. Probably v2 but I guess what's the difference between v1 and v2 ?
  5. What version do I need to flash it to?
  6. Alright guys I hate to be the guy that always has problems but I guess it's just my luck. Here's what I have going. Samsung Tab A6: 1. Using 1.9.39 app ( can't update it to 1.9.40 bc it won't load Json files), keeps crashing (black screen or see pic attached) 2. Won't connect to the adrenaline (If it does see number 1 above, or see pic attached). The Tab A6 Bluetooth see's the Iquad and pairs with it but the app can't find it, or the "Connect to Adrenaline" option is gone. Which I would think means it's paired, but no... all the gauges read zero. 3. The one time it did connect, It would not load any of the tunes I made, then "unfortunately, Iquad has stopped working". I decided to load give up on my Tab A6 for a while and try my phone. Samsung Galaxy S5: 1. Trouble getting it to connect but finally did after 20mins. Tried to load a custom tune.... wait for it.... All tuning variables failed to update!.... What?! ( see second attached pic). 2. See last picture!!!!
  7. What did you mean by fuel load 2*, and tpe reduct to 5* and tps scaling to 50%? I don't see these values options in the App. And Thanks for the reply Ill see if google play has a reader patch app or something.
  8. Okay I downloaded the excel tune builder, built a tune exported it to google drive, downloaded the tune to my galaxy S5 and get the same "All apps associated with this action have been turned off, blocked, or not installed". I've updated the app to 1.9.4 and selected V2 Dodge 1998-2002 and had the app opened first..... I'm at a loss on what to do to get the tune files to work. I thought it was maybe just the Galaxy Tab A, So I re-did everything on my phone. Still same issues. Any Ideas????
  9. Awesome thanks
  10. What do you use for the time value?
  11. Can you explain to me how to use this link for fuel curve?
  12. Thanks for all the patients and help! After a couple of days of trying different things my galaxy tab A7, just refuses to open and run the downloads. Not sure what the issue is? It uses a lollipop operating system for android maybe that's the issue. And yes I'm using 2.5 version dodge v2 98-02 for vehicle setting. I there a place that has these tunes setting so I can manually enter them into my app?
  13. Well that setting make a difference lol
  14. Aight I'll give her a try. The other thing I noticed is this is the only tuning options I have. Where is the rpm timing and boost level fueling etc? I'm doing all this from a galaxy tab A7. If it matters.
  15. So I down load it. Go to "my files" click on the file and get the third picture. Saying "unable to find an application to perform this action". If I try and open it via the drop down window at the top of the screen(where it says down load complete) it gives my that junk folder. Yes Iquad is open prior to download.
  16. Yes I used the link from your videology to get to the down loads. Here's some screen shots ofrom what I get.
  17. Im having trouble getting quad app to open the downloaded file? Keeps opening a junk file or saying unfortunately I quad app has stopped working.... I'm using 1.9.4 app
  18. Thanks for the replies. I just found the V2 bible you are talking about kzimmer. I'll give it a read! And I wasn't so much worried about the gauge being faulty bc i put a manual gauge in place of the sending unit which also had the same bounce, so I think the fuel pressure its reading is correct. I was more concerned the fass system is possible surging. I didn't know if this was normal for fass and I'm just being OCD or I have a fuel supply problem. Thanks you mopar1973man, I'll down load it and look it over. What is safe egt, boost, fuel pressure, timing levels etc..... I'm new to the diesel world and still learning. Also I see people with data log graphs how do I pull my data from the quadzilla so I can read it?
  19. I've recently installed a quadzilla adrenaline with BT unit on my 01 dodge. I have 7x10sac injectors, s362 turbo, head studs, 4" exhaust, new vp44, bhaf, fass 150. I did not wire tap it due to having a new vp44. First, I'm kinda lost on where to start with adjusting the tune in the quadzilla. What's safe? What I can change without wire tap? I've seen the down loads on this site 1.9.4 (app?) and the 2.7.4(tune?) What are these? Second, I get a bounce in my fuel pressure gauge (quadzilla kit) by about 5psi (I'll attach a short video), I'm running a petcock in line to the sending unit. With it turned almost close I can limit the bounce to about 1psi... is this normal? Or do I need to get my shovel out and start digging around the fass system. Thanks for your help! 20171219_180139.mp4
