Cummins_Crazy
Everything posted by Cummins_Crazy
  1. I'll check that out and see if it has any crud on it.
  2. Those vent lines still there with the airdog draw straw?
  3. Will do thanks for the help! If anything changes or happens I'll make sure I update.
  4. Well I'm hoping that's all it was it starts now I haven't driven it I'm a little worried, don't want to break down somewhere again. It's got fuel pressure and fuel at the injectors and it starts so I'm stumped.
  5. Cracked the injectors got a bunch of fuel out of 3 and 4 started cranking tried to start did bless it again tighten them up and it started. Turned it off started it again fired right up. Any thoughts?
  6. Ok I'll try that tonight see if I get any fuel. Fuel pressure right before the VP is 16 she is trying to start but won't fire off. Can you starve the VP with big injectors if you let off the throttle to fast?
  7. Yea getting it towed home after work today and gonna scan it and see if there are any. No check engine light either.
  8. Haven't got a scanner yet, but no codes with key turn.
  9. I was driving to work this morning and the truck just shut off and will crank but not start. Fuel pressure is reading 15-17psi on gauge. Any help would be appreciated. I changed the VP 44 probably 50k ago.
  10. Yea works out pretty good. The tablet connects via Bluetooth to the stereo and to the quadzilla so i can play music off the tablet and use the iquad app.
  11. https://photos.app.goo.gl/sE6SiMMQsbUrCySd6 I still have the head unit the tablet slides in and out.
  12. https://photos.app.goo.gl/Nbt3Hkayook5G6m29 How about that?
  13. I was only able to add a link.
  14. Trying to figure out how to attach photos.
  15. I used a Nexus 7 tablet and took the bezel off and made a fiberglass mold and then bonded it to the bezel in front of the cd player, ill get some pictures of it.
  16. Yea for $400 might be worth trying out.
  17. The turbosmart race port is electronic and uses the tps to know when you chop the throttle. I've have a lot invested in my compounds and would like to prevent any damage done to them that's why I ask. From what I've researched not many diesel have them.
  18. Anyone on here have any thoughts on using a turbo smart blow off valave?
  19. Ok I'll have to order some when I get to Montana thanks for the information on it all. I downloaded a tune from here I think it's called twins with large injectors towing I maybe can tweak that a little since my injectors arnt really large injectors.
  20. Ok I do have studs. When you say little makes me think I should have put some bigger injectors haha I didn't want a ton of smoke is why I went with those.
  21. I've been reading a lot on here about the quadzilla getting comfortable on tuning it with the new setup. We are moving to Montana from New Mexico pulling a 30ft trailer with all the house things. I'm trying to find the best tune for fuel mileage without losing too much power for pulling the hills. I'm new to it so any information would be awesome. I have 7x.009 injectors with a s475 lower and a phatshaft upper i can't quite remember the turbo size I'll look it up and get it though.
  22. Ok that would be awesome thank you!
  23. Sweet thank you for the quick response. We're moving to Montana and I'm gonna need it.
  24. I have the quadzilla iquad Bluetooth with high idle mode can I install mopar1973man high idle switch with the quadzilla on the truck?
  25. That's sweet! I like having the vents also i kept my vents and made a mount for a tablet infront of the CD player
