12vhunter
  1. Just curious would those projectors fit in a second gen housing?
  2. On the 12v there is a prefilter and the heater in a canister thing that is right before the lift pump which is before the fuel filter.
  3. My fuel heater is leaking and I'm wondering if anyone is running without it in cold weather; like a few weeks ago it was -20F and with the wind chill was -40F.
  4. Hi I found a 2002 dodge ram 2500 4x4 with a 5.9 gas engine. I was wondering if it had the same suspension, steering, and brakes, etc. as the diesel.
  5. So Amsoil 75 90 gl4 marine gear lube would work?
  6. Ok thanks guys I guess I'll keep looking for the right stuff
  7. I went to the dodge dealer and he said that atf +4 had to be used in my nv4500. He said it superceded the old oil and when he typed in the part number it kept coming back to the atf +4 so I'm wondering if I can use it.
  8. Hi I just joined this forum so hello to you all. I have a 1996 Dodge Ram 2500 12v cummins 5 spd 4x4 with 725,000km on it and almost as much rust
