Welcometmnm
  1. I just ordered it from Geno’s
  2. I was just looking at that at Geno’s garage. Thank you
  3. Does it matter a particular brand on the APPS, I’ve been wrestling with the dead peddle. I’m trying the best I can to believe my vp is not the problem.
  4. Good to know Gregturley, that speaks volumes! There is plus and minus’s in all decisions. So having a better than stock filter system might be more important to one person. I would have purchased a FASS for that reason seems like a good choice. I personally like the idea of a back up lift pump. Some people carried around a spare lift pump. What’s better than carrying around a spare lift than one that’s already tied into the system. Also I searched high and low for FB failures. In the pump they seem to be nonexistent. Problems have accrued in the bypass valve. Another consideration that played a factor in my choice of the Fuel Boss mechanical pump was an article done up by a member here. That was the RF factor. Something a guy doesn’t see but can play havoc on this generation Dodge.
  5. We got bigger fish to fryHome 2.m4a recording of my brand new Cummins lift pump. My other two never made this stuttering sound. Well that didn’t work out well. The pump sounds like it’s cutting out. The electrical connection is inserted till it clicks. Truck was run about ten minutes after new lift pump install. Just got off the phone with glacier diesel (Richard). Sounds like the fuel is going by the Hobbs switch. All I have to do is increase pressure. Whew!
  6. Probably not a bad idea for a strainer. When I cut into the fuel fill hose, the inside was like it delaminated.
  7. I just installed the Fuel Boss, from Glacier. Richard is a great guy to converse with, very helpful and not in the least pushy. Also waiting on the stock Cummins lift pump from Richard. Earlier I had purchased a Carter from NAPA, and my Quadzilla showed 10lbs psi the first day, and a couple of days later 5lbs down to 0lbs. Followed by an install of the FB, she’s running at 15lbs, which also showed me that the vp44 pressure tap was giving a correct pressure reading. Only question I have is I thought Glacier didn’t recommend a pre-filter. Puts to much strain on the unit.
