cltdba
Everything posted by cltdba
  1. I tried that as well. It made no difference for me.
  2. The resistor is only used during troubleshooting I believe. At least that's what I've gathered. It may be as you suggested, that the scan tools have a resistor built in. <shrug> For my truck, I think the problem lies with the TIPM. According to all of the diagrams I've looked at, everything related to the diagnostic port and the ECM runs through the TIPM. So if I'm not getting any (or enough) voltage for the scan tool to read or if the "handshake" isn't correct then perhaps the TIPM is failing. It's also a circuit board/electronic device. What year is your truck?
  3. From radio shack. You take the resistor and go from Pin 4 to Pin 7 and measure the voltage between the two with the resister in place. (Let me add the "I think" caveat! hehe ) http://www.ross-tech.com/***-com/aftermarket-radio.html
  4. Went to another friends shop and used his Alldata (and some other software) to get wiring diagrams. It appears pins 7 and 12 are not used which explains no power on those. (These are the K and C lines for use with ISO-9141-2.) I located pins 6 and 14 at the TIPM and verified continuity. No breaks in the wire from the OBD2 to the TIPM. (These connect at connector C on the TIPM.) I ran out of time and wasn't able to ohm from TIPM to the ECM, but at least I know which wires I need to look at. If the wiring is good from TIPM to ECM then I guess I'll try replacing the TIPM. Not really sure what else to check? I need to find my own copy of Alldata so I can spend hours looking at the diagrams.Oh, I also tried two more handheld scanners and his $1500 LCD type scanner (forget the name, similiar to Matco Interceptor.) None were able to read. I'm not sure how the Quadzilla Scout II and Matco Interceptor can read. I may even take this thing to another dealership and ask them to diagnose it.
  5. I wish I could say I had this fixed. Unfortunately I just have not had time to dig into this. I've been way to busy working on the race jeep and getting things in order for the next race. The tow rig will just have to wait unfortunately. I'll be sure to come back here and update the thread when I get back to it!
  6. Thanks! I'll be working on this issue again sometime next week. I've saved the image and I'll try to decipher it in my spare time. :D heheh I have a race this weekend and have TONS of work to do on the race Jeep to get it ready for Friday & Saturday.
  7. Still haven't fixed this. I tried replacing the ECM, but it did the same thing. Now I'm leaning towards a problem at the OBD II port. Started researching the port and I "think" I should have voltage on pin 7/K Line when the key is on, but I do not. When I get some more time I plan to start taking the dash apart and tracing wires. I need to do this to fix the floor vent control anyway. It's not working either. The radio is factory, but I wonder if the previous owner had an after market radio in it at some point. I hear that can sometimes cause issues with the OBDII port. If anyone has any knowledge about OBD II please chime in. --------- Pins: 4 = Earth Gnd .859 ohms 5 = Signal gnd .859 ohms 6 = 0 ohms, .68 volts with key on 14 = 0 ohms, .68 volts with key on 16 = 12.5 volts In addition to those pins I have: 7 = 0 ohms, 0 volts (K wire/Diagnostic line?) 9 = 0 ohms, 0 volts 12 = 0 ohms, 0 volts 15 = 0 ohms, 0 volts
  8. No chrome/stainless exhaust for me! :P I want it to stay dark underneath and white on the exterior. FTE was actually my first choice up until I came across the prices at TV diesel. I was going to get their 5" kit. I didn't see a 4" kit on their site. I'll give Walt a call and check the price and see if he has any handy bolt on hangers rather than the weld-on kind. --edit-- was going to upload a pic of my truck, but it seems the editor isn't mac friendly. http://forum.mopar1973man.com/image/jpeg;base64,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
  9. Thanks everyone for your help! I feel the 4" kit is the way to go. Now where to buy it? I'm leaning towards TV diesel. (Found out about them from a post here on this forum) They seem to have the best price around and it's a Diamond Eye kit. I like the DE kit because of the u-bolt brackets with hangers. I have yet to wire 220 to my shop so I can't use my welder and this would make things easier. TV Diesel Diamond Eye 4" Aluminized Kit with Muffler And I'll be ditching the u-bolt clamps and going with some of the EZ seal band clamps. Those seem to do a better job and make things easier if i want to change it up later down the road. As far as installation, obviously I would put the cat just after the downpipe. Would you put the muffler directly after the cat or put pipe in between it and the cat?
  10. Excellent thread! This explains why my truck feels laggy without the cat. With the cat my VE percentage is likely lessened, but my "light to light" response is better. In theory, if I'm in the city and have the cat on, I should save fuel because the truck won't need to supply as much fuel to build boost to get the truck moving. As for increasing the exhaust size...Assuming my math is correct, the 4" exhaust is way bigger than the turbo's exhaust outlet, so there shouldn't be any flow issues. There's not really any chance for an overspeed condition, even with the cat on. The only valid point for upgrade to a 5" that I can see is if I were running a larger turbo. I don't know the exact turbo in my truck, but I'm pretty sure it's not a VG. I assume HY35? Anyways, even if it were a VG it's not going to be fully open most of the time so 4" would still be sufficient. I think I'm going to go for the 4" exhaust so I can experiment with the cat and how it affects EGTs. It's also a bit cheaper than the 5". If at some point I find the exhaust is somehow limiting me from creating more power then I can spend the money on the 5" I guess. --- Update to the previous post... So what's your opinion on 4" vs 5" on a stock truck? I will be adding the smarty jr and will likely run it on 40 HP while towing and 70HP unloaded. (Having some issues with reading the ECM, but once I get that fixed I'll be buying the smarty.) Might even opt for a SR or SSR. Still more research to do on each.
  11. Now that makes a lot of sense! Now we just need a Holset engineer to chime in!
  12. I think the whole point of the back pressure debacle is related to the amount of time it takes to build spool. More back-pressure = faster spool? I'm assuming that's why the truck feels more responsive on take-off with the cat in-line. At WOT I imagine having an unrestricted exhaust would be more beneficial. However, I know nadda dang thing about anything of this and am just guessing. :P
  13. Thanks again everyone!
  14. There's no such thing as a hijacked thread in my opinion. If something I posted causes more questions then that means I probably didn't think of everything. All of it is good info. Between truck and trailer I'm only averaging about 12-13k. On occasion I will hit the 20K mark but it's rare. I haven't installed my EGT probe yet. I've got 1,000 more miles before the warranty runs out and I've been avoiding it until then. Anyone still have the cat on that can speak to EGTs?What about the "back pressure" bit, anyone know anything?
  15. That's kind've how I feel about the 5", but everyone raves about it. Perhaps it's that bigger is better mentality? In my 2007, I have plenty of room for the 5", but I still think it's overkill. But then I don't want to buy a new 4" kit only to later upgrade it to 5".My current setup is 4" aftermarket that was installed by previous owner. It's falling to pieces and needs to be replaced. Seems going back with 4" gives me the most options. I suppose if at some point I decide to make tons of power out of this truck, I could upgrade to 5". I don't see that being the route I take anytime soon though. I hate the drone I have now so I'm definitely contemplating a resonator or leaving the cat in place. Was thinking about doing a 4" kit with muffler and leaving my cat in place. Also thought about doing a 4" kit, removing the cat and adding 30" FTE resonator/muffler. But before I decide on any route to go I'd like to understand back pressure and how it affects a diesel engine.
  16. What's the consensus on "back pressure" in our diesels? I hear they don't need back pressure and it makes no difference. It seems my 2007 has more low end torque with the cat installed when on stock tune than when I remove the cat. It seems very sluggish on take off as it the turbo needs time to spool in order to get the truck rolling. In higher RPMs it seems stronger though? In order to gain back that low end torque I have to tune it. Why is this so? I need to replace my exhaust and as much as I want to go with 5" for lower EGTs and better sound, I'm afraid it's going to hurt my performance. My truck is stock and I don't want to throw a tune on it and put other parts in danger, just to get the off the line power. Thought I'd pose this question here as I've gotten tons of mixed reviews elsewhere.
  17. Diesel shop I was working with got in touch with Marco I believe. I'll shoot Bob an email see if he has any idea.
  18. Thanks everyone! Truck is in my sig line.
  19. Tried updating the tuner, no such luck. Tuner is a superchips cortex. They even tried downgrading the tuner to see if that worked. Unfortunately, haven't been able to try an updated Smarty yet.
  20. Charlotte, NC here
  21. Chances of me finding someone with one of those is very unlikely. Most everyone I know is running a Smarty and rely on it for diagnostics. :P I'll check the local shop to see if by chance he has one.
  22. Been lurking here and using the various resources of the site since I bought my first CTD for Christmas/New Years. Finally decided to join the forum the other day. Not much to tell about me I don't guess. I'm 32 years old and live just north of Charlotte, NC. I'm a database administrator for a large financial company that works heavily with automotive lending. :D I bought my truck to haul my rock crawler and for general purpose use. My father was a diesel mechanic for the larger part of his life, but somehow I never managed to gain any diesel knowledge from him. Did pick up on a ton of gasser knowledge though. :D Enjoying my first diesel. I've had some problems with it, but am slowly getting those worked out. It's been hard not to dump tons of money into it. Quite a fun hobby in itself!Oh, by the way, CLTDBA = Charlotte Database Administrator
  23. May have missed it, but you have a link to the Y cable?
  24. The prices at tvdiesel are far cheaper than anywhere I've seen yet. I was wanting to go with FTE kit and one of their 30" resonator/mufflers. But now I'm eyeballing that low priced diamond eye exhaust kit. Wonder what the drone is like. Still would be cheaper for me to go with diamond eye and an FTE muffler than doing the FTE kit + muffler.
  25. - 2007 Dodge Ram 2500 5.9L CTD- Superchips Cortex 3950 - Innova Can ODB-II 3100e scanner Tuner was working fine before a trip to the dealership. I had a problem where my wait to start light was coming on at highway speeds. Also threw P1222. All of this happened after tuning truck with superchips cortex tuner. (I had the tuner left over from my previous gas truck, thought I'd see what it could do.) So I put the truck back to stock and took it to the dealer for repair. Dealer installed 6 new injectors. I still had the WTS light problem, but was able to use my code scanner to check DTCs. That's how I found the P1222. Hooked up a friends fancy Matco scanner and it was unable to connect the truck. After that, I could no longer connect my Innova scanner either. I thought it was just fluke and took it to the dealer to fix the P1222 and WTS light.Dealer replaced FCA and PRV which in turn fixed my WTS/P1222 problem. After getting the truck back, I attempted to connect my programmer to the truck. It came up with error saying it couldn't detect ignition on. I then tried my Innova scanner and it said it was unable to connect to the vehicle. I then tried the programmer in a friends Jeep and it was able to connect and tune it with no issue.I took the truck back to the dealer for this new problem. They were unable to find any problem and said the issue was with my scanner. (Didn't tell them about programmer.) I then asked them to try reflashing the truck. They stated after the injector change that I already had the latest software, but I wanted to see if they would run into errors like I did. They did not have any problems flashing the truck with their DRB3 tool. I actually went back with them and watched them do it. I then went to a local diesel shop who was so very kind to open a brand new Smarty JR and see if it would connect. It didn't throw errors, but also could not connect. It kept going through the key on/off cycle. After about 5 tries we gave up. Just this past weekend, I ran into a friend with the new Smarty SSR. I had him attempt to connect to my truck and it also did the exact same thing.Does anyone have any idea what this might be? I'm thinking bad ECM and am prepared to replace it, but I don't want spend the cash and that not be the problem. So far, Superchips, Innova and MADS haven't been able to confirm what might be wrong. MADS suggested a bad ECM. (On another note, I'm extremely impressed with MADS customer service considering I haven't even bought their product yet. If I can get this truck working I will be purchasing one asap. Already have my Quadzilla Scout II which interfaces with the smartys.)
