RdieselZ
Everything posted by RdieselZ
  1. Thanks for the feedback. I'm going to be upgrading my stock hy35 with compounds sxe62 over s475 and other goodies this winter so I'm thinking of going to need to upgrade my boots. I should be in the 500-600hp range from what I'm told after upgrades. If or when I need new boots, Who makes the best boots/clamps?
  2. I'd like to know how these hold up compared to more expensive brands like mishimoto
  3. ^ this tune Me. Would it be safe to change timing to 17,20,23,28,30?
  4. ^ this tune Me.
  5. Got a question, so Is brokepainters stock dd tune look like a very good tune for a mainly stock truck? I would like to know because I've read alot of how I should tune towards my stock truck and his tune is quite different than what I hypothetically came up with. Would his tune be a good base for me to try and maybe adjust if and where needed for a stock daily driver/fun ride ? Thanks
  6. Finally got the quad hooked up. I had a short somewhere in my data link wires from ecm. I cut the wires just out of the ecm and spliced the quad to that. Success! ?. Also to note. I was misinformed on the quad data link color wires. I said (B) blue and (A) green. The CORRECT quad data link wire colors are (B)purple and (A) pink. So the correct connection is (B)yellow/blue stripe to (B) purple. And (A)yellow/green stripe to (A) pink. Thank you for your guys help.
  7. I've looked at this diagram 10 times just noticed the A,B,C ?‍♂️?‍♂️?‍♂️ I feel really stupid rn. I hope that is all I need to do is swap them wires. That would be fantastic lol. Will find out tomorrow! I just hope I didnt cause any damage connecting it wrong.. Thank you for your help and pointing out the obvious Me!!! ?
  8. Are you telling me I have to swap my wires?
  9. Can anyone confirm if my data link wires are spliced correctly? I spliced the wire from truck wiring yellow/blue line with the solid blue wire(B) in the quad data link harness. I then spliced the other wire from truck wiring yellow/green line with the solid green wire(A) in the quad data link harness. There was also a black wire (truck wiring side) but i did not wire that to anything. On the quad harness there was a 3 prong connector labeled A,B,C. A was solid green wire. B was solid blue wire. C was no wire. Also I dont think it has anything to do with what I have done but my speedometer does not work now. I really need to try and get this all figured out. I finally got the truck back after leaving it with a body guy for a ton of body work and paint the last 10.5 months and I really want to enjoy the truck before I have to store it for winter in 2 months. Thanks for any help!
