flagmanruss
  1. What's scary is the transformer it's connect to is supposed hide under the chair. Because the 9V cells were prone to fail when needed most, I'd put the transformer on a shelf at arm rest height... but on my weak side is all that's available. But if this had melted down when I was asleep... it could have caused a FIRE way too close to my body. I really don't want to go out that way. I wonder of the outfit selling these components will replace it on my say so? Glad I bought a spare... I usually do... because you never know about these cheap widgets.
  2. I'll have to wait until there's someone here so I can try gettng into the truck, the cab step not withstanding. i habe a history of falls & that would really screw up my day. I've likely had MS a long time, the Neurologist who diagnosed me correctly in 2001 went over my records & indicated events going back 15 years at that point. I have been in the later Secondary Progressive phase since 2002. The fact I can still get around on my own at all, means I'm doing better than most in my position.
  3. i have a habit of sleeping in a power recliner... which is great except when the power goes out. The built in (2) 9v transistor radio batteries really don't cut it... so I sliced in (2) 6 in series AA battery holders which is better. The motor is rated 30 volts so I decided to up the power by swappng the 6 series for 8 series AA battery holders (24vdc). I needed 2, so I ordered 3. I swapped my nearly new AA cells in & added new to make my 8 cells in each. Glad I was working on my desk. One of the holders shorted ONE AA cell. The coil spring on the negative was off center & somehow got in contact with the cell case which is positive. Dead short! So the cell quickly became too hot to touch... just that one cell. The battery holder wasn't connected to anything... no other shorts. Somehow I pried the smoking little battery out before anything melted. Yeah, that was fun.
  4. Yes, I'm aware of these other issues but this is a front end/ wheel & brake shop & they've caught things other places missed. My truck is used very little these days is still low mileage. Could it be this simple? I'll let you know as soon as I can get into the truck for a test drive. Yes, the sedentary lifestyle created by my disability has a lot of potential for trouble.
  5. I had my truck in the shop... for some reason they were dragging their feet about getting to it... I was getting annoyed but then I had a 3 day vacation in the ICCU (Intermediate Cardiac Care Unit), after a first ever episode of A-Fib. OH, yeah, after getting evac'ed in a Rescue before breakfast. Home now & getting used to the additional meds besides my existing disability. I've been unhappy with the way the truck tracks... have to constantly be on it making small adjustments. Already did track bar upgrade. He replaced the steering damper... said it was frozen or siezed. ??? We'll see. Had a bunch of routine maintance done since I can't do myself; brake lines, replaced leaking rear axle seal, oil change. Yes, my CC took a hit.
  6. Wife/grand-daughter found mice have chewed rear seat belts trying to get up through hole between seat cushions. After previously finding mice in cabin air filter, we opened the cowel, checked cabin air intake & plugged drains with SS pot scrubbers. She checked the cabin air filter NOW & found it to be fine. This is how the fresh air gets INTO the cabin. We suspect the mice are getting in through the REAR somehow. [My Dodge Avenger has a cabin air OUTLET in the trunk behind the carpeting "near the gas fill". It only goes through the trunk wall, not the outter fender & has a one way flapper on it.] I don't know where the cabin air goes out of the Hundai... it "must have" or it would blow up like a balloon... or no outside air could circulate. I had no luck on Google... Does anybody know where the Hyundai cabin air OUTLET is? It would save me a ton of searching. THX.
  7. I don't know why the shop didn't want to use parts store parts. After I'd suggest he check with Cummins NorthEast, I felt I couldn't refuse. It's home, we are using the truck. No problems. At the end of the day, that's what is important.
  8. I built an extension harness for my 79 Chevy C30... It would plug into the bumper connector & thread under the tailgate inito the truck bed. I reused the harness, I used a hole cutter to clearance he bedliner on the Dodge & then installed the FM plug in the bed wall behind the rear axle. I had to cut the ears off the M plug to feed it through the hole in the bed wall. The harness in now secured along the frame & the M plug is baggied & rides on top of my trailer package F plug under the bumper. It avoided making any cuts in the OEM wiring. & worked perfectly. In recent years, I use solder & heat shrink tubing for trailer wiring. I don't want to be re-doing it EVER!
  9. The damages: Cummins water pump 1 year/100,000 mile guarentee $195 Serpentine belt $65 Thermostat $69 Antifreeze 3.5G $69 Labor $145 Disposal $4.45 Total With Tax $557 Ouch! It sorks paying retail. Picked the truck up... had to drive through heavy traffic both ways... An hour round trip took 2 hours.
  10. I don't know why the mechanic doesn't want to use the AutoZone water pump. I can only guess he desn't trust it. The new pump from Cummins (not reman from Dodge) is supposed to be $100 less than the $275 dealer... so I'm expecting $175. I'm also getting a flush, new coolant, thermostat & belt.
  11. Wife took it in a shop there just now. They are trying to source the pump. I did not think that would be a problem. The shop doesn't want to use a pump from AutoZone... dealer wanted 275 for a re-man & a week to get it. I suggested they check with Cummins NorthEast in Dedham, Ma. A new Cummins pump is being overnighted. Problem solved.
  12. What sort of time should a general auto shop spend on a water pump change on a high 4X4 (stock, non-lifted but it's high)? I'm assuming it will take longer than a flat rate where one only needs to ean over a fender. Thanks guys.
  13. OK, so once the serpentine belt is off, might as well have a new belt put on... the labor is the same. I doubt there'd be a problem getting a water pump but Cummins NorthEast is in Dedham, Ma as I recall. Too far to drive losing coolant but a parts source if worst comes to worst. ~30 miles up Interstate 95... I don't travel well, but if the incentive is enough, within range.
  14. Nothing else? New or rebuilt water pump? Any other quirks I should know about?
  15. No. She recommended a nearby Midas shop who's been doing her work. I have no experience with this one.
  16. 2001.5 Dodge 2500. It's parked in stepdaughter's yard in Attleborough, Ma near Pawtucket, RI. I have a couple of days. It's leaking coolant at front of engine. It's pretty wet but the center of the wet is the water pump. I don't know who to take it to that I can trust. With my MS, I can not do my own work.
  17. I found this older trailer to have a rugged steel frame underneath & in the walls... but the skin is a mixed bag. Coated aluminum on the sides with plated steel screws (some rusting) into the side frames, galvanized steel for the roof into the steel arches & some type of molded plastic for the curved front. Interestingly, the top of the front is a molded piece... locared under the front & top, not over (to shingle the water away). The seams between these different materials were done with "camper caulk" putty type... and screws run through both panels into strips of 3/4" plywood. Where the caulk was not leaking, I left it be. But the top molded nose piece seam had been leaking where the water ran down the front, staining the interior plywood liner. There was a 1" aluminum trip strip over this seam. I removed the screws, drilled out the steel self tappers that broke & drilled for #10 SS through bolts, walkers & nylock nuts... My wife used underwater grade "LifeCaulk" on the seam & with one of us on the inside & one outside we worked the pieces from the center to the outside. Then we smoothed up extruded caulk with paint thinner. I don't see any more leaking. The price seemed right on this trailer too. It has not been the bargain I expected. I think it'll be a good unit...
  18. I've been a little busy, trying to rehab my knee from my recent fall while living home alone. I don't own a Linux computer so I guess I can't make a useful post about a Linux Ransomware attack.
  19. I don't get a new topic button. And I get logged out after just a couple of minutes. If you don't want me to post, just say so.
  20. Vitamin D has been studied... not proven effective but indeed is low in people with MS. I upped my dose to 2000IU daily. (2) 5000IU daily may be over kill. There is research showing good preliminary results using high dose B7 (Biotin)... not practical to do with OTC but compounded works or you can buy powder & do yourself. 100mg 3X daily. My Neurologist has Rx for me. There are not any modern pharma drugs which have much effect for SP MS. There are what as known as DMT (Disease Modifying Therapy) which can slow down but not stop MS... in the early stage. I take meds to manage symptoms around the clock.
  21. I stayed quite active 10+ years of symptoms all the way through Relapsing Remitting MS. I was not correctly diagnosed until the major events of 2001-2 when I was transitioning to the Secondary Phase. Here I am 13 years later... I spend way more time sitting than I like, these days... I have very limited minutes I can be on my feet. While there is nothing wrong with the muscles, the damaged nerves are like a bundle of frayed wires. Some don't work at all (numbness), some work a little but a "high resistance joint" (nerve fatigue), some are like crossed wires (tingling, sensation like some bug is crawling on you). I use walls & furnature for stability... a cane is unstab;le but sometimes necessary. I have 2 walkers upstairs, one down, one in the car. A big outdoor scooter, a foldup scooter that lives in my car. (The last with a "souped up" custom LiFePO4 battery & smart charger.) I tore this same knee in late 2008, surgury early 09 did what could be done. Has had a dead spot in the lift range since. I must use a lot of right arm strength to climb stairs or to get into the truck. One foot on a banana peel & any new injury could stop life as I know it. I have made an initial appt with the Orthopedic doctor. I hate to go to the big city office but that was how to get it expedited. I expect an MRI will be ordered... won't know the actual damages until then.
  22. My Multiple Sclerosis has progressed... about all MS is progressive... and I am 13 years into the Secondary Phase. This is all background. Both legs are affected, the left side is nearly non-functional & the left arm too. I despite my best efforts, I've had falls... I used to bounce back up... then I had to work to get up... A couple of days ago, I fell off the low stool trying to put a belt on the lawn tractor. I really tried but in the end, I had to use my cell to get help. I'm afraid my right (good) knee may have been injured (ACL is tender). I have to climb stairs with my right leg (and right arm strength)... and the same to get onto my truck step. I seriously question if I could get into the truck today. I just don't know where I go from here.
  23. Gainful employment... especially something you are good at... is never something to be sneezed at. The economy is still very spoty. Make good decisions for yourself & we'll be fine.
  24. Mine 01.5 is a automatic so not much help. I can look for the solinoid if anyone needs me to.
  25. At one time, it was pretty common to have corrision problems on the soloniod located under the battery shelf...
